Help: Auto Zoom to Interference Points
ngdnam88
ngdnam88
Dears,
I'm using this iLogic from this post to detect interference.
https://clintbrown.co.uk/2019/02/03/interference/
On Error GoTo Error1 ' Code adapted from the Inventor API Sample to work with iLogic by Clint Brown
'Code originally posted at https://clintbrown.co.uk/interference
    Dim oDoc As AssemblyDocument
     oDoc = ThisApplication.ActiveDocument
    ' Find all selected occurrences and add them to an ObjectCollection.
    Dim oSelectedOccs As ObjectCollection
     oSelectedOccs = ThisApplication.TransientObjects.CreateObjectCollection
    Dim i As Long
'    For i = 1 To oDoc.Select.Count
For i = 1 To oDoc.SelectSet.Count
        If oDoc.Select.Item(i).Type = kComponentOccurrenceObject Then
            oSelectedOccs.Add(oDoc.Select.Item(i))
    Next
    Dim oResults As InterferenceResults
    Dim oCheck As ObjectCollection
     oCheck = ThisApplication.TransientObjects.CreateObjectCollection
    If oSelectedOccs.Count = 0 Then
        ' Add all occurrences to the object collection
        Dim oOcc As ComponentOccurrence
        For Each oOcc In oDoc.ComponentDefinition.Occurrences
            oCheck.Add(oOcc)
        Next
        ' Get the interference between everything.
         oResults = oDoc.ComponentDefinition.AnalyzeInterference(oCheck)
    ElseIf oSelectedOccs.Count = 1 Then
        ' Add all occurrences except the selected occurrence to the object collection.
            If Not oOcc Is oSelectedOccs.Item(1) Then
                oCheck.Add(oOcc)
        Next
        ' Get the interference between the selected occurrence everything else.
         oResults = oDoc.ComponentDefinition.AnalyzeInterference(oSelectedOccs, oCheck)
    Else
        If MsgBox("Check interference between selected occurrences and all other occurrences?", "@ClintBrown3D", vbYesNo + vbQuestion) = vbYes Then
            ' Add all occurrences except the selected occurrences to the object collection.
                ' Check to see if this occurrences is already selected.
                Dim bSelected As Boolean
                bSelected = False
                For i = 1 To oSelectedOccs.Count
                    If oSelectedOccs.Item(i) Is oOcc Then
                        bSelected = True
                        Exit For
                Next
                If Not bSelected Then
                    oCheck.Add(oOcc)
            Next
            ' Check interference between the selected items.
        Else
             oResults = oDoc.ComponentDefinition.AnalyzeInterference(oSelectedOccs)
    If oResults.Count = 1 Then
        MsgBox("There is 1 interference.")
    ElseIf oResults.Count > 1 Then
		MessageBox.Show("There are " & oResults.Count & " interferences.", "@ClintBrown3D")
    If oResults.Count > 0 Then
		Dim oHS1 As HighlightSet
        oHS1 = oDoc.CreateHighlightSet
        oHS1.Color = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
        Dim oHS2 As HighlightSet
         oHS2 = oDoc.CreateHighlightSet
        oHS2.Color = ThisApplication.TransientObjects.CreateColor(0, 255, 0)
        For i = 1 To oResults.Count
            oHS1.Clear
            oHS2.Clear
            oHS1.AddItem(oResults.Item(i).OccurrenceOne)
            oHS2.AddItem(oResults.Item(i).OccurrenceTwo)
         	MessageBox.Show("Occurrences are highlighted from interference " & i, "@ClintBrown3D")
        Next
        oHS1.Clear
        oHS2.Clear
    Else
		MessageBox.Show("There is no interference :)", "@ClintBrown3D")
Return
Error1 :
MessageBox.Show("We ran into a problem, Please ensure that you are in an assembly file, or try the manual Interference Checker", "@ClintBrown3D")
Please help me the code that can Zoom to Each Interference points as this picture
It's same zoom function after using "Analyze Interference"
Thank you very much!
bradeneuropeArthur
Use this piece of code:
    Dim i As Long
    Next
            oCheck.Add(oOcc)
        Next
                oCheck.Add(oOcc)
        Next
    Else
                bSelected = False
                        bSelected = True
                        Exit For
                Next
                    oCheck.Add(oOcc)
            Next
        Else
		MessageBox.Show("There are" & oResults.Count & " interferences.", "@ClintBrown3D")
'Dim oCamera As Camera
'oCamera = ThisApplication.ActiveView.Camera
' 'MsgBox(oResults.Item.OccurrenceOne)
'   Dim NewTargePnt As Inventor.Point = oResults.Item(1).OccurrenceOne.RangeBox.MinPoint
'   NewTargePnt = ThisApplication.TransientGeometry.CreatePoint(NewTargePnt.X, NewTargePnt.Y)
'   oCamera.Target = NewTargePnt
'   Call oCamera.SetExtents(40, 40)
            oHS1.Clear
            oHS2.Clear
   				Dim NewTargePnt As Inventor.Point = oResults.Item(i).OccurrenceOne.RangeBox.MinPoint
   				NewTargePnt = ThisApplication.TransientGeometry.CreatePoint(NewTargePnt.X, NewTargePnt.Y, 0)
   				Call oCamera.SetExtents(10, 10)
   				oCamera.Apply
        Next
        oHS1.Clear
        oHS2.Clear
    Else
Return
Error1 :
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JelteDeJong
probably not as good as the solution of @bradeneuropeArthur but it took me some time to see his solution. So i figured that I could post this solution also.
Dim selctionSet = oDoc.SelectSet
selctionSet.Clear()
selctionSet.Select(oResults.Item(i).OccurrenceOne)
selctionSet.Select(oResults.Item(i).OccurrenceTwo)
ThisApplication.CommandManager.ControlDefinitions.Item("AppZoomSelectCmd").Execute()
Jelte de Jong
Blog: hjalte.nl - github.com
bradeneuropeArthur
    Dim i As Long
    Next
            oCheck.Add(oOcc)
        Next
                oCheck.Add(oOcc)
        Next
    Else
                bSelected = False
                        bSelected = True
                        Exit For
                Next
                    oCheck.Add(oOcc)
            Next
        Else
            oHS1.Clear
            oHS2.Clear
   				NewTargePnt = ThisApplication.TransientGeometry.CreatePoint(NewTargePnt.X, NewTargePnt.Y, NewTargePnt.Z)
   				oCamera.Apply
        Next
        oHS1.Clear
        oHS2.Clear
    Else
Return
Error1 :
Thanks @JelteDeJong  , appreciated.
I have modified it a bit after cross-check!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
