Adding linear drawing dimension to an assembly via API - Face Proxies fail
jonas.hoffmeisterFYFHQ
Hi everyone,
I am trying to add dimensions to an assembly. The relevant faces within the parts are named. I manage to get the components but I cannot get the drawing curves. Here is my code:
' Adding Dimensions
Dim oAssembly As AssemblyDocument
oAssembly = oSideView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oModelDoc As Document
Dim Face1 As Face
Dim Face2 As Face
For i = 1 To oAssembly.ReferencedDocuments.Count
	oModelDoc = oAssembly.ReferencedDocuments(i)
	If oModelDoc.AttributeManager.FindObjects("*", "*", "Nutenseite1").Count > 0 Then
		Face1 = oModelDoc.AttributeManager.FindObjects("*", "*", "Nutenseite1").Item(1)
		MessageBox.Show("Found: " & Face1.InternalName()) ' this works! Named Object found!
	If oModelDoc.AttributeManager.FindObjects("*", "*", "Nutenseite2").Count > 0 Then
		Face2 = oModelDoc.AttributeManager.FindObjects("*", "*", "Nutenseite2").Item(1)
Next
Dim oOccFace1Proxy As FaceProxy
Dim oOccFace2Proxy As FaceProxy
Dim oCompOcc As ComponentOccurrence
oCompOcc = oAssembly.ComponentDefinition.Occurrences.ItemByName("Einlaufpfostenprofil")
MessageBox.Show("Selected Component: " & oCompOcc.Name()) 'Works!
Call oCompOcc.CreateGeometryProxy(Face1, oOccFace1Proxy) 'no error msg here. Programm does not fail
Call oCompOcc.CreateGeometryProxy(Face2, oOccFace2Proxy) 'no error msg here. Programm does not fail
Dim myCurveCandidates As DrawingCurvesEnumerator = oSideView.DrawingCurves(oOccFace1Proxy)
MessageBox.Show(oSideView.DrawingCurves(oOccFace1Proxy).Count) 'gives me a zero
Dim myDrawingCurve As DrawingCurve = myCurveCandidates.Item(1) 'fails
Dim face1GeoIntent As GeometryIntent = oSheet.CreateGeometryIntent(myDrawingCurve)
myCurveCandidates = oTopView.DrawingCurves(oOccFace2Proxy)
myDrawingCurve = myCurveCandidates.Item(1)
Dim face2GeoIntent As GeometryIntent = oSheet.CreateGeometryIntent(myDrawingCurve)
Dim widthDimPoint As Point2d = oTG.CreatePoint2d(15, 10)
oSheet.DrawingDimensions.GeneralDimensions.AddLinear(widthDimPoint,face1GeoIntent,face2GeoIntent)
Michael.Navara
It can be. Because your face proxy may be hidden by another one. Following code produces two zero results for first occurrence and non-zero result for second one in sample drawing.
Sub Main()
    Dim drawing As DrawingDocument = ThisDoc.Document
    Dim drawingView As DrawingView = drawing.ActiveSheet.DrawingViews(1)
    Dim asm As AssemblyDocument = drawingView.ReferencedDocumentDescriptor.ReferencedDocument
    For Each occ As ComponentOccurrence In asm.ComponentDefinition.Occurrences
        Logger.Debug(occ.Name)
        Dim occPartDef As PartComponentDefinition = occ.Definition
        Dim faces As Faces = occPartDef.SurfaceBodies(1).Faces
        For Each face As Face In faces
            If face.SurfaceType = SurfaceTypeEnum.kPlaneSurface Then
                Dim faceProxy As FaceProxy = Nothing
                occ.CreateGeometryProxy(face, faceProxy)
                Dim faceCurves As DrawingCurvesEnumerator = drawingView.DrawingCurves(faceProxy)
                Logger.Debug(faceCurves.Count)
        Next
    Next
End Sub
Sorry, I have some issue with sample dataset uploading... 😕
Just screenshot at this time
Michael.Navara
Today upload works 🙂
In attachment is a sample assembly with code snippet.
Thanks!
Omg, I wasn´t aware that hidden objects (via flush or similar) can cause troubles like this. Now that I spent the play around with your code and mine I got this sorted!
My code changed quite a bit. Final version below.
Thanks again for the sample file. Awesome help!
' Adding Dimensions
Dim oCompOcc1, oCompOcc2 As ComponentOccurrence
Dim oPartDoc1, oPartDoc2 As PartDocument
Dim oEdge1, oEdge2 As Edge
Dim oFace1, oFace2 As Face
Dim oEdge1Proxy, oEdge2Proxy As EdgeProxy
Dim oFace1Proxy, oFace2Proxy As FaceProxy
Dim oGeoIntent1, oGeoIntent2 As GeometryIntent
Dim myNamedEntities As NamedEntities
Dim myPos2d As Point2d
' MyPart
oCompOcc1 = oAssDoc.ComponentDefinition.Occurrences.ItemByName("MyPart")
Logger.Debug("Selected Component: " & oCompOcc1.Name())
oPartDoc = oCompOcc1.Definition.Document
myNamedEntities = iLogicVb.Automation.GetNamedEntities(oPartDoc)
oFace1 = myNamedEntities.FindEntity("Nutenseite3")
oFace2 = myNamedEntities.FindEntity("Nutenseite4")
Call oCompOcc1.CreateGeometryProxy(oFace1, oFace1Proxy)
Call oCompOcc1.CreateGeometryProxy(oFace2, oFace2Proxy)
myCurveCandidates = oSideView.DrawingCurves(oFace1Proxy)
Logger.Debug("Curves Count: " & myCurveCandidates.Count)
oGeoIntent1 = oSheet.CreateGeometryIntent(myDrawingCurve)
myCurveCandidates = oSideView.DrawingCurves(oFace2Proxy)
oGeoIntent2 = oSheet.CreateGeometryIntent(myDrawingCurve)
myPos2d = oTG.CreatePoint2d(oSideView.Left + oSideView.Width + 1, oSideView.Top - oSideView.Height - 1)
oSheet.DrawingDimensions.GeneralDimensions.AddLinear(myPos2d,oGeoIntent1,oGeoIntent2)
