Inventor ilogic rules, form, and parameter to autocad
M_Santi
M_Santi
Is it possible to have the ilogic rules, form, and parameter to transfer over to autocad when I export my drawing template to autocad? When I open autocad the drop down for the attribute doesnt work where I can select my multi-value parameter. The rules that apply also doesn't transfer. How would I code it so that it works in autocad?
A.Acheson
Unfortunately there is no crossover of this information it will only work inside inventor.
Regards
Alan
M_Santi
So ilogic only works in inventor and there's no way to code it into autocad?
A.Acheson
Autocad will have there own objects and methods. You can ask on the Autocad Customization forum. Any reason you want to modify inventor drawings in Autocad? There different software and they don't have seamless transitions.
Regards
Alan
