Heavy Performance Issue When Query MassOverridden
c_hoppen
Message 1 of 9
c_hoppen
I have stumbled across a pretty heavy performance problem. It seems that the query of MassProperties.MassOverridden leads to a recalculation of the mass.
Have a large assembly open (around 2,000 files  or more). Run the code below. In my case I have 2381 files open and the code takes about 2 minutes (i9-9900k, 32 GB RAM, SSD)
Sub Main()
Dim assmDoc As AssemblyDocument
Set assmDoc = ThisApplication.ActiveDocument
Dim assmDef As AssemblyComponentDefinition
Set assmDef = assmDoc.ComponentDefinition
Dim massProps As MassProperties
Set massProps = assmDef.MassProperties
Dim isOverridden As Boolean
isOverridden = massProps.MassOverridden
End Sub
 Inventor 2022.3.2 Build 350.
Is this a known issue?
Christoph
Replies (8)
Message 2 of 9
bradeneuropeArthur
Sub Main()
massProps.CacheResultsOnCompute = False
MsgBox (isOverridden)
End Sub
Use this!
oMassProps.CacheResultsOnCompute = False
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
c_hoppen
doesn't make a difference! Same time consumption!
I measured the influence of the two settings on the query time:
CacheResultsOnCompute = False is faster, but waiting one minute for a "yes or no" ist still unacceptable.
Message 4 of 9
bradeneuropeArthur
Is there any other kind of coding used in your company via i-logic VBA Vb.net etc that runs parallel?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
bradeneuropeArthur
Do you have the option calculate mass for assemblies and parts on save on?
You can find the application options.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 6 of 9
c_hoppen
No.
Message 7 of 9
c_hoppen
No, it's Part Only.
To make it clear: I don't want to calculate the mass. I just want to know if the mass in the top assembly is overridden. The answer should be a quick "yes or no" and not "let me think about it some minutes".
Message 8 of 9
bradeneuropeArthur
I know, but with this option on the mass is already calculated on forehand, which seems to be the issue with your models.
I think that inventor needs first to update the mass before it will know if it is overwritten or not.
The mass properties are a bit special properties which is hard to explain and complex.
Maybe you can first test if this option on is solving your problem, because I personally have no issue with large assemblies and your code.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 9
c_hoppen
I tried it with several other Assemblies having more than 1.000 unique files loaded an the result is always the same.
(with massProps.CacheResultsOnCompute = False)
What is large to you?
My first sample is the Express Mode Demo "Osgood" from 2015 (55 sec.)
I did a test with the "Material Process Line" Sample having 1263 files and it takes about 23 seconds.
Another sample was the "Large Assembly Sample" coming with the Adesk Poket Demos (31 sec.)
In contrast to the first example, the last one is faster, because in the first one the geometries are much more complex.
For me there is no reason to do any calculation, only to find out if a bool value is true or false.
Christoph
