GUID for "Inventor Vault" for inventor application 2023
khadeerkruthi
khadeerkruthi
hi Team,
The below code will get the GUID of "Vault Standard Data", Similarly I was trying for "Inventor Vault".
Public Sub Main()
Activate()
End Sub
Public Sub Activate()
Dim VaultStandardData As ApplicationAddIn
VaultStandardData = ThisApplication.ApplicationAddIns.ItemById("{3AD251E3-02DD-4B8C-8882-86C97C80E00C}")
VaultStandardData.Activate()
VaultStandardData.LoadAutomatically = True
VaultStandardData.Deactivate()
VaultStandardData.LoadAutomatically = False
End Sub
bradeneuropeArthur
Run this piece of code:
And you will find a text file on "C:\ApplicationAddins\"
Public Sub Main()
Dim aa As Inventor.ApplicationAddIn
For Each aa In ThisApplication.ApplicationAddIns
	WriteText(aa.DisplayName & " - "& aa.ClientId, "Addins")
	Next
End Sub
	Public Sub WriteText(StrTextToWrite As String, Optional strFileName As String = "File3")
        Try
            Dim FileNameTekstfile As String = Nothing
            Try
                FileNameTekstfile = strFileName '"UserName
            Catch ex As Exception
            End Try
            Try
                MkDir("C:\ApplicationAddins\")
            End Try
            Dim FILE_NAME As String = "C:\ApplicationAddins\ " & FileNameTekstfile & ".txt"
            Dim objWriter As New System.IO.StreamWriter(FILE_NAME, True)
            Try
                objWriter.WriteLine(StrTextToWrite)
            End Try
            objWriter.Close()
        End Try
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
