Check-in Vault from Inventor without pop-up window
m_baczewski
m_baczewski
I am preparing automation for creating models and drawings. I have already written all the logic, and everything works correctly. The only issue is that during the automatic entry of drawings or models, I get a pop-up window where I have to press OK to enter it. Is there a way to skip this window automatical?
Part of code to check in:
Dim countReferenced As Integer = oDoc.AllReferencedDocuments.Count
	For i As Integer = 1 To countReferenced + 2
		ThisApplication.ActiveDocument.Save2()
		Dim oControlDef As Inventor.ControlDefinition
		oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
		oControlDef.Execute()
		ThisApplication.ActiveDocument.Close
	Next
ThisApplication.SilentOperation = True
Isnt working on Vault addin, its only working for inventors pop up.
Can you help me? 😄
bradeneuropeArthur
You need to use the Vault API for that.
What version of Vault are you using?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
m_baczewski
Hi @bradeneuropeArthur
Vault professional 2022
