Message 1 of 19
- Mute
- Permalink
- Report
I'm looking to create something that functions similar to "Copy properties" for dimensions, but not exactly the same.
I'd like to create a global form that operates on a drawing like this:
- User clicks to activate the form.
- User chooses (on the form) from a predefined set of modifiers (see below for examples), or writes in a custom one in a text box.
- User chooses (on the form) whether it should appear before/after the dimension.
- User clicks on a dimension (not on the form), and the modifier gets added before/after that dimension.
- User clicks on more dimensions, adding the same prefix/suffix to all of them.
- User hits escape or closes the form to continue using Inventor normally.
The examples that come to mind are things like the diameter symbol, "2X", "3X", "5X", STK, etc.
Is this possible?
