give drawing same description as assembly
Geertvdheide92
Message 1 of 8
Geertvdheide92
I am trying to create a dwg template where the description of an assembly is the same as the description of the dwg.
I know it is possible to get model properties in text boxes inside the dwg.
But i cant get these properties in the dwg properties.
I was thinking op putting the code <DESCRIPTION> in the description box of the dwg, but it doesnt do anything.
In text boxes i can choose property type and property. Can i also select a property type with <....> code?
kind regards
Geert van der Heide
Replies (7)
Message 2 of 8
Rob67ert
I use this in an iLogic code:
modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
iProperties.Value("Project", "Description") = iProperties.Value(modelName, "Project", "Description")
iProperties.Value("Project", "Part Number") = iProperties.Value(modelName, "Project", "Part Number")
iProperties.Value("Project", "Project") = iProperties.Value(modelName, "Project", "Project")
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 3 of 8
Geertvdheide92
this is working great, thanks!
But this isnt possible with a simple link, it looks like it is used in text boxes?
because the model properties should be somewhere in the dwg i guess, but i cant find them.
Message 4 of 8
bradeneuropeArthur
You can do that without I logic:
Keep reading.....
Define your template this way and you do not need coding....
If you need help please let me know.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 8
Rob67ert
I will put all the information i have in the iproperties of the part or assembly. Like the Description it should be the same for the part as for the drawing file I make from it.
I have some iLogic rule run automatically that will do all that work form me.
Robert
Message 6 of 8
Geertvdheide92
in my current template these settings are already set.
But i can only get these properties in text boxes, and not in the dwg properties.
Message 7 of 8
bradeneuropeArthur
They are in the drawing properties already when checked as seen in the picture.
the only action required is:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 8
Geertvdheide92
Aha, i didnt know that button,
Thank you very much!
