Tolerance - limts/Fits using iLogic
Hope this is not I duplicate post - I searched the forum and couldn't find the answer.
I was looking for help on how to set ISO limits/fits through iLogic.
So for example...say I have a shaft Dia. 100 mm (Nominal), how do I add a 'g6' tolerance to this through ilogic?
I have been using set median then set deviation (+/-) to comply with ISO standard, but this seems a bit cumbersome, especially when doing this over a range of shaft diameters...
Anyone point me in the right direction?
Best regards.
Stuart
Stuart,
    I am new to this game so please forgive me if I am over simplifying. Could you set up a dimension style that has the tolerances you need in a template file, then just apply that style to the appropriate dimensions?
Respectfully
Kevin
