Insert IFeature with workplane and workpoint
martinhoos
Message 1 of 8
martinhoos
Hello All,
i have a iFeature that i like to insert with an ilogical-code. The iFeature is called LongPilot, it formed the end of a tube. The tube diameters are 10, 12, 16 and 18mm.
I dont know how....
Thank you in advance.
Regards from germany
Martin
Replies (7)
Message 2 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Try the following iLogic code. Before running code, make sure that path of ide file is updated.
Public Sub Main()
	Dim oPartDoc As PartDocument
	oPartDoc = ThisApplication.ActiveDocument
	Dim oPartDef As PartComponentDefinition
	oPartDef = oPartDoc.ComponentDefinition
	Dim oWorkPoint As WorkPoint
	oWorkPoint = oPartDef.WorkPoints("Center Point")
	' Get the selected face to use as input for the iFeature.
	Dim oFacePlane As WorkPlane
	oFacePlane = oPartDef.WorkPlanes("XZ Plane")
	Dim oFeatures As PartFeatures
	oFeatures = oPartDef.Features
	' Create an iFeatureDefinition object.
	Dim oiFeatureDef As iFeatureDefinition
	oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("Path of ide file")
	' Set the input.
	Dim oInput As iFeatureInput
	For Each oInput In oiFeatureDef.iFeatureInputs
		Dim oParamInput As iFeatureParameterInput
		Select Case oInput.Name
		Case "Durchmesser"
		Dim oTubeDia As iFeatureParameterInput
		oTubeDia = oInput
		oTubeDia.Expression = "16 mm"
		Case "Skizzierebene1"
		Dim oPlaneInput As iFeatureSketchPlaneInput
		oPlaneInput = oInput
		oPlaneInput.PlaneInput = oFacePlane
		Case "Referenzpunkt1"
		Dim oRefPoint As iFeatureEntityInput
		oRefPoint = oInput
		oRefPoint.Entity = oWorkPoint
		End Select
	Next
	' Create the iFeature.
	Dim oiFeature As iFeature
	oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
End Sub
Please feel free to contact if there is any queries.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 8
martinhoos
Hi chandra,
thank you very much for your reply... i tried your code, the ifeature is placed at the Center Point and XY plane.
Is there a possibility to choose a workpoint and a work plane while the code is running? May be a question like: "Pick a workpoint and a workplane"
Thank you for your help...
Regards Martin
Message 4 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Yes, you can try the following iLogic code.
Public Sub Main()
	oWorkPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPointFilter, "Select a point to place iFeature")
	oFacePlane = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Select a Plane to place iFeature")
	' Set the input.
		Case "Durchmesser"
		oTubeDia = oInput
		oRefPoint = oInput
		End Select
	Next
End Sub
If solves problem, "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 8
martinhoos
Hello chandra,
thank you very much! Your code did it - great work....   🙂
Regards Martin
Message 6 of 8
martinhoos
Hello Chandra,
i have modified my iFeature but i did not get it runing. Please can you look at the code and modify it?
The iFeature shouldt match with copper pipes Ø10, Ø12, Ø16 and Ø18mm.
Regards Martin
Message 7 of 8
chandra.shekar.g
Autodesk Support
Autodesk Support
@martinhoos,
Try below modified iLogic code with respect to previously attached iFeature file(.ide).
Public Sub Main()
	' Set the input.
		Case "durchmesser"
		oTubeDia = oInput
		Case "Ebene1"
		Dim oPlaneInput As iFeatureWorkPlaneInput
		Case "Punkt1"
		oRefPoint = oInput
		End Select
	Next
End Sub
Meanwhile, iFeature is failed to add into part document through UI as well. I think, model is failed to regenerate after updating parameter(durchmesser). On parameter update, below error is thrown.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 8
martinhoos
Hello Chandra,
thanks for your reply! I get the same fault - so i have to go back to our first solution.
Thanks a lot for your help.
Regards Martin
