Getting Thumbnail from BOM Row
Raider_71
Raider_71
Any idea why I cant get the Thumbnail iProperty from a document object derived from a BOM row? If I do this then it does not work:
oCompDef = oRow.ComponentDefinitions.Item(1)
Dim oDoc As Inventor.Document = oCompDef.Document
Dim thumbnail As stdole.IPictureDisp
thumbnail = oDoc.Thumbnail
If I use apprentice then it works:
Dim strFilename As String = oDoc.FullFileName.ToString
Dim oApprentice As New Inventor.ApprenticeServerComponent
Dim oApprDoc As ApprenticeServerDocument
oApprDoc = oApprentice.Open(strFilename)
thumbnail  = oApprDoc.Thumbnail
Using apprentice is not a problem but I feel that it could slow my program down having to use apprentice.
Any idea why I cant use the Document object derived from a BOMRow object like I have above?
Owner2229
Hi, I believe you have to open the document in order to get it's thumbnail, so:
Dim oTempDoc As Inventor.Document oTempDoc = InventorApplication.Documents.Open(strFilename, False) Dim thumbnail As stdole.IPictureDisp thumbnail = oTempDoc.Thumbnail oTempDoc.Close
Anyway Apprentice does actualy work faster with documents, but it ofc. depends on what else you're doing with the documents.
There's been test for it. E.g. For reading iProperties it should work 10x faster then visible Inventor and 2x faster then invisible Inventor.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Raider_71
Hi thanks for the feedabck.
I was hoping to not open the document at all and just work from the component definition as I am able to extract all the other properties that way. Was hoping to extract the Thumbnail that way as well.
Its strange that the Thumbnail property is there but it does not work. Why have it there at all then...
adam.nagy
Autodesk Support
Autodesk Support
1) What do you mean by "does not work"? Do you get an error? Or the returned value is simply "Nothing"?
2) Is your program an add-in or a standalone application? Because you cannot access IPictureDisp from a separate process, and it's nothing Inventor specific, it's just a limitation of IPictureDisp: https://msdn.microsoft.com/en-us/library/office/ff864458.aspx
Cheers,
Adam Nagy
Autodesk Platform Services
Raider_71
Hi Adam,
Ok thats the answer then. Cant call it from another process - its a standalone application. My app is running out of process...
Thanks for getting back to me!
