ilogic - list all custom properties
tegstette
Message 1 of 8
tegstette
HiSmiley Happy
Can someone help me out with a code that lists all custom properties for all instances in an entire structure?
I want to run the rule from the top assembly and get a list of all the custom properties used. Cannot find any similar rules for this...
Best regards
TG
Autodesk Inventor/Vault Professional 2021
Replies (7)
Message 2 of 8
Owner2229
Hi, try this code below. I suggest export it to an text file instead of showing in MsgBox, as the list might be a bit long.
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim Docs As DocumentsEnumerator = oDoc.AllReferencedDocuments
Dim aDoc As Document
Dim Pros As New ArrayList
Dim item As String
For Each aDoc In Docs
    Dim oPropsets As PropertySets
    oPropsets = oDoc.PropertySets
    Dim oPropSet As PropertySet
    oPropSet = oPropsets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
    Dim oPro As Inventor.Property
    For Each oPro In oPropSet
        Dim Found As Boolean = False
        For Each item In Pros
            If oPro.Name = item Then Found = True
        Next
        If Found = False Then
            Pros.Add(oPro.Name)
    Next
Next
Dim AllPros As String = "List of all used iProperties:"
    AllPros = AllPros & vblf & item
Next
MsgBox(AllPros)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 8
tegstette
Hi
I tried the rule, but I get an error:
Invalid class string (Exception from HRESULT: 0x800401F3 (CO_E_CLASSSTRING))
more info:
System.Runtime.InteropServices.COMException (0x800401F3): Invalid class string (Exception from HRESULT: 0x800401F3 (CO_E_CLASSSTRING))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.PropertySets.get_Item(Object Index)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Best regards
TG
Message 4 of 8
tegstette
Seems like there is something with this line:
oPropSet = oPropsets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF​9AE}")
Best regards
TG
Message 5 of 8
Owner2229
Hi, it works for me with the Key reference, but you can try it like this:
Also, are you using iLogic, VBA or VB.Net?
Dim item As String
    oPropSet = oPropsets.Item("Inventor User Defined Properties")
        Next
            Pros.Add(oPro.Name)
    Next
Next
    AllPros = AllPros & vbLf & item
Next
MsgBox(AllPros)
Mike
Message 6 of 8
tegstette
Thank youSmiley Happy
I use ilogic. The rule now lists all custom properties that has a value. But how do I get it to show all custom properties - also the empty ones...? I tried to alter the rule, but the inventor froze... so I guess what i tried was bad...:-)
Best regards
TG
Message 7 of 8
tegstette
Hi, again!
I figured it out, must have done something wrong the first time.
I just comment this line and it worked:
Thank you very much, works greatSmiley Happy
Best regards
TG
Message 8 of 8
tegstette
Hi
I was a little bit quick to accept this. I thought I had fiured it out, but when I study the result of my changes was not correct…
Can you help me out again?
Best regards
TG
