Mass from different Levels of Detail
I want to write the mass of 3 different LODs in one Drawing. How can I calculate the mass for those LODs and show it on the Drawing?
Thanks!
rossano_praderi
Hi Goncalves,
here attached there is a possible solution for your question.
I've create this sample with the release 2016, let me know if you have any trouble.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
xiaodong_liang
Autodesk Support
Autodesk Support
Hi F.Goncalves,
I believe what Rossano Praderi shared in message 2 is the solution. Thank you Rossano Praderi!
To help more customers, I posted a blog based on this solution. I made some adjustment on the code.
Could you check it and mark message of  Rossano Praderi or me as the solution?
http://adndevblog.typepad.com/manufacturing/2016/03/inventor-ilogic-dislay-mass-from-different-lod-o...
core codes:
'get RepresentationsManager
Dim repMgr As RepresentationsManager = ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager
'record current LevelOfDetailRepresentation
Dim oCurrentRepName As String  = repMgr.ActiveLevelOfDetailRepresentation.Name
Dim oRep As LevelOfDetailRepresentation
Dim oRepName
Dim oMass
For Each oRep In repMgr.LevelOfDetailRepresentations
    oRepName = oRep.Name
    'activate this LOD
    repMgr.LevelOfDetailRepresentations.Item(oRepName).Activate
    'get mass
     oMass = iProperties.Mass
     'update value of custom property
     iProperties.Value("Custom", oRepName) = iProperties.Mass
Next
'restore
repMgr.LevelOfDetailRepresentations.Item(oCurrentRepName).Activate
rossano_praderi
Hi Xiaodong Liang,
I was pleasantly surprised by your message and I want to thank you for giving me mentioned in your blog post "Manufacturing Devblog".
Also, I think that your explanation published on the blog is more complete and clear of mine, therefore more helpful.
Bregs
Rossano Praderi
software
i tried to apply the solution of getting mass for different level of detail. but in the drawing output, i couldnt find a way to change the decimal points to zero. inventor puts in the mass value with 10 decimal places. i even tried changing the units of assembly in document settings but did not succeed.
can you please let me know how to change this.
rossano_praderi
Dear Mr.Software....
....below you can find a possible solution....
iProperties.Value("Custom","Mass")=Str(Floor(iProperties.Mass)).Replace(",","")
Bregs
Rossano Praderi
