Getting the vault status of a Non-Autodesk File with iLogic, and update local file
ccoomes
ccoomes
I am after the help of the experts and users here.
We have a lot (over 40,000) Solid Edge files, that we have placed vault and starting to migrate over to Inventor for our CAD software.  There is not a Vault Add-in for SE, so it does not tell you when your local copy is out of date...
However, there will be situations that we will need to modify the SE data. when the SE data is checked out, modified and checked in, there is nothing (That we know of) that will tell all the other users that the SE file has been modified.  the only thing I can find that shows the file is out of date, is the 2 red arrows on the Vault Status icon.
Ideally, I would like to create a search in Vault, and then filter the Vault Status to only show the files that are out of date.  Nope, apparently you cannot filter on the Vault status, or do Autodesk deem it not essential and are not looking into the feature...  This has shocked me as every other engineer I have worked with who uses vault, always says how do it check my workspace for out of date files....  this is a different subject that I am raising with Autodesk through other means....
Back on Topic...
Has anyone been able to use iLogic to search non-Autodesk files and get their status from Vault?  this is the process I am thinking of:
1. Search a Directory & sub Directories for parts with file extension *.par
2. Check the Vault Status of each file, and if out of date get the latest copy
This sounds like a very simple process but I cannot get it to work.
Has anyone been able to do this successfully?
Below is the code I have created, but I cannot get it to get the vault status for the files.   Hopefully it is something very simple...
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports AWS = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
AddReference "QuickstartiLogicLibrary.dll"
Imports VB = Connectivity.Application.VaultBase
Imports System.Diagnostics
Class ThisRule
	Private oVaultState1 As String = "CheckOutState"
	Private oVaultState2 As String = "ConsumableState"
	Private oVaultState3 As String = "ErrorState"
	Private oVaultState4 As String = "LocalEditsState"
	Private oVaultState5 As String = "LockState"
	Private oVaultState6 As String = "RevisionState"
	Private oVaultState7 As String = "VersionState"
	Private oVaultState8 As String = "NotCheckedOut"
	Sub Main
		'[ **********    Check if Connected to Vault    **********
		Dim mVltCon As VDF.Vault.Currency.Connections.Connection = VB.ConnectionManager.Instance.Connection
		If mVltCon Is Nothing Then
			MessageBox.Show("Not Logged In to Vault! - Login first and repeat executing this rule.")
			Exit Sub
		Dim processPath As String = "C:\Vault Working Folder\CAD Data\"
		Dim TxtFileName As String = processPath & "Files_Found.txt"
		Dim Folder As New IO.DirectoryInfo(processPath)
		Dim MyFile As String
		Dim MyLocalFile As String
		Dim VaultPath As String
		Dim FileCount As Integer = IO.Directory.GetFiles(processPath, "*.ipt", IO.SearchOption.AllDirectories).Length
		Dim FileExt As String = ".ipt"
		Dim TxtFileText As String = processPath
		WritetoFile(TxtFileName, TxtFileText, False)
		Dim mDocVaultStatus As Dictionary(Of String, String)
		'[		'Check local path for .par files...
		For Each File As IO.FileInfo In Folder.GetFiles("*" & FileExt, IO.SearchOption.AllDirectories)
			MyFile = File.fullname
			VaultPath = MyFile
			VaultPath = VaultPath.Replace("C:\Vault Working Folder\", "$/")
			'flip the slashes
			VaultPath = VaultPath.Replace("\", "/")
			Dim VaultPaths() As String = New String() {VaultPath }
			Dim wsFiels() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
			Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn, wsFiels(0))
			Dim lifeCycleInfo As VDF.Vault.Currency.Entities.FileRevisionInfo
			MyLocalFile = GetVaultFileStatus(MyFile)
			'If MyLocalFile = False Then
			TxtFileText = MyFile & " | " & MyLocalFile
			WritetoFile(TxtFileName, TxtFileText, True)
			'GetFileFromVault(VaultPath)
			'End If
		Next
		MessageBox.Show("Done")
	End Sub
	Private Sub WritetoFile(TxtFileName As String, TextToAdd As String, Optional ByVal AppendToFile As Boolean = True)
		'Dim dateString = DateTime.Now.ToString("yyyy_MM_dd_HH_mm_ss")
		'Dim TxtFileName As String = ThisDoc.PathAndFileName(False) & "_" & dateString & ".txt"
		If AppendToFile = True Then
			'____Open and append to an existing text file_______
			Dim oAppend As System.IO.StreamWriter
			'oFile = TxtFileName
			oAppend = IO.File.AppendText(TxtFileName)
			oAppend.WriteLine(TextToAdd)
			oAppend.Flush()
			oAppend.Close()
		Else
			'____Create and write to a text file_________________
			oWrite = System.IO.File.CreateText(TxtFileName)
			oWrite.WriteLine(TextToAdd)
			'oWrite.WriteLine("File Created on " & DateString)
			oWrite.WriteLine("")
			oWrite.Close()
	End Sub
	Public Function GetVaultFileStatus(LocalFullFileName As String) As String
		mDocVaultStatus = iLogicVault.GetVaultFileStatus(LocalFullFileName)
		If mDocVaultStatus.Item(oVaultState1) = oVaultState1 Then
			GetVaultFileStatus = oVaultState1
		If mDocVaultStatus.Item(oVaultState2) = oVaultState2
			GetVaultFileStatus = oVaultState2
		If mDocVaultStatus.Item(oVaultState3) = oVaultState3
			GetVaultFileStatus = oVaultState3
		If mDocVaultStatus.Item(oVaultState4) = oVaultState4
			GetVaultFileStatus = oVaultState4
		If mDocVaultStatus.Item(oVaultState5) = oVaultState5
			GetVaultFileStatus = oVaultState5
		If mDocVaultStatus.Item(oVaultState6) = oVaultState6
			GetVaultFileStatus = oVaultState6
		If mDocVaultStatus.Item(oVaultState7) = oVaultState7
			GetVaultFileStatus = oVaultState7
		Else
			GetVaultFileStatus = "Other"
		' This code gives you the values of the Status,
		'		For Each kvp As KeyValuePair(Of String, String) In mDocVaultStatus
		'			Dim v1 As String = kvp.Key
		'			Dim v2 As String = kvp.Value
		'			Trace.WriteLine("iLogic: " + v1 + " Value: " + v2)
		'		Next
	End Function
End Class
  Any help or guidance would be greatly appreciated.
bradeneuropeArthur
If you know the local path of the file you could also get the vaultstatus of the file using the Vault API. I prefer creating a addin, because of the possibilities. Also I think ilogic is more a thing for product configuration and not for this kind of complex thing. So I think this is possible.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
