VBA Macro - Open Document Silently
isocam
isocam
Can anybody help?
Is it possible, using a VBA macro to open an Inventor "Part" (ipt) silently (Hidden), without showing it on the screen and get the Part's "description" property, then close the part?
For test purposes only, I want to open a "Part" silently and get the part's description property and show it in a msgbox?
Many thanks in advance!
Kind Regards
Darren
WCrihfield
Hi @isocam.  Maybe something like this?
Sub OpenPartHidden()
    Dim oPDoc As PartDocument
    Set oPDoc = ThisApplication.Documents.Open("C:\Temp\MyPart1.ipt", False) 'False = hidden
    Dim oDescProp As Inventor.Property
    Set oDescProp = oPDoc.PropertySets.Item(3).Item("Description")
    Dim sDesc As String
    sDesc = oDescProp.Value
    Call MsgBox(sDesc, vbOKOnly, "Part Description")
    oPDoc.ReleaseReference
    Call ThisApplication.Documents.CloseAll(True) 'True = unreferenced only
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
