Change Material from .idw
CGVJM6DF
CGVJM6DF
It is possible to change the part material with a iLogic rule from .idw?
Andrii_Humeniuk
Hi @CGVJM6DF . Yes, of course it is possible. This question has already been asked several times, here are some ready-made solutions: link , link , link . If you have any problems, we are happy to help you.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
CGVJM6DF
thanks @Andrii_Humeniuk ,
But that's not what I want.
I need a rule for the .idw (Drawing) template, that will change/add a material to the part (sheet metal) it belongs to.
A.Acheson
Hi @CGVJM6DF
Please provide the method how you currently do this manually. Images of the method will clarify the request. Your description currently has multiple possibilities.
Regards
Alan
CGVJM6DF
Hi @A.Acheson
I didn't do it yet. I ask if it is possible to assign a material to the part, with a rule, running it from the drawing of the part.
Andrii_Humeniuk
This iLogic code change material your part from drawing.
Public Sub Main()
	Dim oInvApp As Inventor.Application = ThisApplication
	Dim oDDoc As DrawingDocument = TryCast(oInvApp.ActiveDocument, DrawingDocument)
	If oDDoc Is Nothing Then Exit Sub
	Dim oViews As DrawingViews = oDDoc.ActiveSheet.DrawingViews
	If oViews.Count = 0 Then Exit Sub
	Dim oDoc As PartDocument = TryCast(oViews(1).ReferencedDocumentDescriptor.ReferencedDocument, PartDocument)
	Dim oList As New List(Of String)
	For Each oAssetlib As AssetLibrary In oInvApp.AssetLibraries
		For i As Integer = 1 To oAssetlib.MaterialAssets.Count
			oList.Add(oAssetlib.MaterialAssets(i).DisplayName)
		Next
	Next
	oList.Sort
	Dim sMat As String = InputListBox(oDoc.DisplayName, oList,
										oDoc.ActiveMaterial.DisplayName, "Asset Libraries.", "Select Material:")
	If String.IsNullOrEmpty(sMat) Then Exit Sub
	If oDoc.ActiveMaterial.DisplayName = sMat Then Exit Sub
	Dim oNewAsset As Asset
			If oAssetlib.MaterialAssets(i).DisplayName <> sMat Then Continue For
			oNewAsset = oAssetlib.MaterialAssets(i)
		Next
	Next
	Try : oDoc.ActiveMaterial = oNewAsset
	Catch : MessageBox.Show("Failed to change material!", "Error!", MessageBoxButtons.OK, MessageBoxIcon.Error) : End Try
End Sub
CGVJM6DF
Cool, Thanks @Andrii_Humeniuk
