Get Parameter Name from Parameter in iLogic
johnster100
johnster100
i'd like to be able to retrieve a parameters name from it's 'blue' parameter name in ilogic like shown below (the below code does not work).
Is this possible?
thanks,
John
bradeneuropeArthur
With this:
A = Parameter.Param("test1")
MsgBox (A.Name)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
johnster100
thanks for the reply.
I'm trying to keep the parameters in their 'blue' state so that if the name changes they update. It would also let me write some more flexible subs where I could pass the blue parameters in and set their values.
thanks again,
John
