Get name of current ilogic rule
Curtis_Waguespack
Consultant Consultant
Message 1 of 14
Curtis_Waguespack
Is there a way to get the name of the current ilogic rule, when it runs.
Something like this:
'get iLogic addin
Dim iLogicAuto As Object
iLogicAuto = iLogicVb.Automation
'get collection of rules
Dim rules As Object
rules = iLogicAuto.rules(ThisApplication.ActiveDocument)
'make sure there are rules in the file
If Not (rules Is Nothing) Then
    For Each rule In rules
        'write rule to debugger
        If rule.Name = ThisRule.Name Then
        Trace.WriteLine(rule.Name, "iLogic")
    Next
Thanks in advance,
Curtis
Replies (13)
Message 2 of 14
Hi Curtis,
Is it your intention to specifically avoid using a MessageBox? Otherwise, perhaps the simplest solution would be to add MsgBox("Your rule name here") as the first program line in your rule text.
Message 3 of 14
Curtis_Waguespack
Hi jwterminator1,
Thanks for the reply.
My intention here is really just not to have to know the name of rule, and have the code write out the name of the rule that is running to the debugger:
http://adndevblog.typepad.com/manufacturing/2014/08/debug-ilogic.html
But whether it's the debugger or message box, currently the best I can do is what you suggest, which is to type in the name at the top of the rule.
Thanks again,
Curtis
Message 4 of 14
After a quick browse through the object references in the various iLogic dlls that I could find, I didn't an accessible pathway to access the information regarding currently running iLogic rules so you may only be left with the hard coded name method which you could still send through to the debugger.
Message 5 of 14
MechMachineMan
See attached excel in the linked thread for your own look at the exposed calls in the iLogic api.
https://forums.autodesk.com/t5/inventor-customization/ilogic-api-documentation/td-p/6785772
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 6 of 14
Curtis_Waguespack
Hi MechMachineMan,
Hey thanks for taking the time to post that.
In looking through that XLS file I find this:
            Autodesk.iLogic.Interfaces.iLogicRule.Name
But I'm still unclear how to call that from the iLogic rule.
When I compare it to the line calling the rules collection it looks like this:
            Autodesk.iLogic.Interfaces.IiLogicAutomation.Rules(Inventor.Document)
So does that mean iLogicRule.Name is not part of IiLogicAutomation add in?
I see another user was trying to do much the same thing here in the past, but there isn't any reply or solution:
https://forums.autodesk.com/t5/inventor-customization/get-the-name-of-ilogic-rule/td-p/3425633
I wonder if @wayne.brill can give me a nudge in the right direction?
Curtis
Message 7 of 14
MechMachineMan
From what I could find, using the iLogicVB call only provides access to the Autodesk.iLogic.Interfaces.ILowLevelSupport object, and trying to call iLogicVB.Automation only provides access to the Autodesk.iLogic.Interfaces.IiLogicAutomation.
So I tried to go around this with the code below by accessing the iLogic addin and then accessing interfaces from there so I could access the Autodesk.iLogic.Interfaces call directly.
Trying this leads me to believe either the code I have doesn't allow me to access the Interfaces directly, or I have to use some other call to access Interfaces from the addin ie;
oiLogicInterfaces = addin.iLogicInterfaces
With my limited knowledge so far, I'm not sure if it's even possible to use intelli-sense or object browser to find out if I can go deeper, so at this point I have run out of usefulness. Hopefully one of the Autodesk folk can chime in and help us out here!
VB.Net version of code.
Sub Main()
    Dim iLogic As Object
    iLogic = GetiLogicAddin(ThisApplication)
    If (iLogic Is Nothing) Then Exit Sub
    Dim doc As Document
    doc = ThisApplication.ActiveDocument
    Dim i As Integer
    'MsgBox(iLogic.Interfaces.iLogicRule.Name)
End Sub
Function GetiLogicAddin(oApplication As Inventor.Application) As Object
    addIns = oApplication.ApplicationAddIns
    Dim addIn As ApplicationAddIn
    'On Error Goto NotFound
    addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
    If (addIn Is Nothing) Then Exit Function
    addIn.Activate
    MsgBox(addin.Description)
    MsgBox(addIn.Interfaces.iLogicRule.Name)
    Return addIn
    Exit Function
    NotFound:
End Function
Justin K
Message 8 of 14
Curtis_Waguespack
Autodesk Customer Support wrote: (via email)
Dear Curtis Waguespack,
Support Case12523678 (Get name of current ilogic rule) is now closed. If you still need help with this issue, please reply to this email and include additional details. You can also review or respond to your support cases online in your Autodesk support portal.
Autodesk is committed to providing excellent customer service. As part of the support process, we may send you an optional survey for your feedback.
Thanks for contacting Autodesk for support.
Best regards,
Developer Technical Services
I received this message via email. And replied with this:
Curtis_Waguespack wrote: (via email)
I assume this is just an automated message, but it misses the mark considering that there was not response from Autodesk on the actual question. If the answer is it can't be done, that's okay.
But no response to the question, and then messages informing the customer that the case is being closed, makes Autodesk support look quite bad.
Then I received the same email shown above 3 more times.
Smiley Surprised
anyway, I'm giving this thread one more bump, so ......bump!
Message 9 of 14
MjDeck
Hi Curtis,
There is no way to get the name of the calling rule from the iLogic system. That would definitely be useful. We can add it in a future release.
Mike Deck
Software Developer
Autodesk, Inc.
Message 10 of 14
Curtis_Waguespack
Hi MjDeck,
Thanks for confirming this for us.
And yes if we could do this in a future release that would be outstanding!
Thanks again,
Curtis
Message 11 of 14
WCrihfield
Maybe I'm missing something, but the quickest and easiest way I know of to get the name of the currently running rule using iLogic is the following line:
iLogicVb.RuleName
Wesley Crihfield
(Not an Autodesk Employee)
Message 12 of 14
MjDeck
@WCrihfield , that method was not available in Inventor 2018 and earlier.
Thanks for posting. I forgot to announce the new function on this thread.
Mike Deck
Software Developer
Autodesk, Inc.
Message 13 of 14
Maxim-CADman77
@MjDeck
Any possibility to get external rule's FullFileName (directory and/or extension)?
Please vote for Inventor-Idea Text Search within Option Names
Message 14 of 14
MjDeck
Hi Maxim,
Yes, that would be relatively easy to do. I created a user story (internal number INVGEN-71847). We should be able to do it soon, but maybe not in the 2025 release.
Mike Deck
Software Developer
Autodesk, Inc.
