Get the name of ilogic rule
theo_bot
Message 1 of 1
theo_bot
Hi there,
I want to get the rulename from a rule so i can set it to a string.
i found this, but for some reason it doesn't work:
- <member name="P:Autodesk.iLogic.Interfaces.iLogicRule.Name">
  <summary>Get or set the name of the rule.</summary>
  </member>
I can loop tru all the rules of my document, but i cann't figure out why the single rule name is not working. I must miss something.
this is a part of a external rule where that i use to add a rule based on a text file, it checks if the rulename that i fill in exists in the current rule list of that file:
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 8499
StartFragment: 314
EndFragment: 8467
StartSelection: 314
EndSelection: 314
'aanroepen Ilogicautomation
auto=iLogicVb.Automation
'declareren van rule en rules als object, rules is een lijst van alle aanwezige rules in het document
DimruleAsObject
DimrulesAsObject
rules=auto.rules(oDoc)
'teller klaarzetten
i=0
'Doorloop de aanwezige rules en controleer of er al een rule met gelijke benaming bestaat
If(NotrulesIsNothing)Then
ForEachruleInrules
Ifrule.Name=RulenameThen
MessageBox.Show("Een rule met de naam: "&rule.Name&" bestaat al", "Title")
i=i+1
EndIf
Next
'voeg de rule toe, indien de naam nog niet bestond
Ifi=0Then
auto.AddRule(oDoc, Rulename,FileContents)
EndIf
can somebody give me a hint??
thanks
Replies (0)
