Get GUID of other add in
gert-leonvanlier
gert-leonvanlier
I want to acces the Vault add in in Inventor. It looks like that I need the GUID of this add in. Is there a way to find this GUID or any other method to access the Vault add in?
bradeneuropeArthur
Inventor Vault {48B682BC-42E6-4953-84C5-3D253B52E77B}
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
gert-leonvanlier
Thank you very much!
But is there a way to find the GUID myself?
bradeneuropeArthur
you can use this in VBA:
Public Sub GUID()
Dim inv As Inventor.Application
Set inv = ThisApplication
Dim a As Inventor.ApplicationAddIn
For Each a In inv.ApplicationAddIns
'MsgBox (a.DisplayName & "" & a.ClassIdString)
Debug.Print a.DisplayName & "" & a.ClassIdString
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
