Updating a View/Model from a Drawing with iLogic
chris.johnstoneQP8NN
Message 1 of 13
Hi guys, I trying to figure out how to update a View (Model file) within a drawing while running some iLogic code.
The iLogic code I'm running, inside the drawing, changes some parameter sizes in the referenced model. However, these changes do not update the drawing view. I have tried things like:
iLogicVb.UpdateWhenDone = True
and
InventorVb.DocumentUpdate()
 However, this only works if the drawing as a whole needs updated (as far as my understanding goes).
Right clicking on the View and updating is the only way I can get it to work but as I want the whole process to be automated, obviously this is no use. Any ideas?
Thanks in advance!
Replies (12)
Message 2 of 13
JhoelForshav
Hi @chris.johnstoneQP8NN
I just did some testing and what worked for me was to first update the actual referenced document. I'm sure you have it stored in a variable in the code since you're updating its parameters. Say you call it oDoc. Then just add the line:
oDoc.Update
Then after that line, update the sheet the view is on (the views parent).
If you dont have it stored in a variable you can call:
oView.Parent.Update
Hope this helps 🙂
Message 3 of 13
Thanks for the quick reply @JhoelForshav! I have inserted what you said and I'm getting this error message. Any ideas?
Message 4 of 13
JhoelForshav
I see.. You're using an iLogic snippet to get the view so it's not an object of type DrawingView... You could probably get the DrawingView object from that though. Could you share your code? 🙂
Message 5 of 13
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oView As DrawingView
oView = ActiveSheet.View("VIEW1")
oDoc.Update
oView.Parent.Update
 This is just a bi of test code I'm trying to get to work but this is coming up with an error. I appreciate your help @JhoelForshav!
Message 6 of 13
JhoelForshav
What needs to be updated is the model document (not drawing document) and the sheet.
I hope this makes sense to you.
'Dont really need the drawing document for this
'Dim oDoc As DrawingDocument
'oDoc = ThisDoc.Document
oView = ActiveSheet.View("VIEW1").View 'Add .View to get the DrawingView object.
Dim oModelDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument 'Get the model document
'Do whatever you do to change model parameters here
oModelDoc.Update 'Upodate model document
oView.Parent.Update 'Update the sheet
Message 7 of 13
Thanks @JhoelForshav that's the one. I appreciate your help
Message 8 of 13
roberto_infanti
I have N View with non-consecutive names (View1,View2,View34,.....). How could I do the update to all views? Thanks
Message 9 of 13
Curtis_Waguespack
Hi @roberto_infanti,
Here is a quick example that looks at all the sheets, and all the views and updates the model document and view.
I hope this helps.
Curtis
Dim oSheets As Sheets
oSheets = oDoc.Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
For Each oSheet In oSheets
	oSheet.activate
	oViews = oSheet.DrawingViews
	For Each oView In oViews
		oModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
		oModelDoc.Update
		'Update the sheet
		oView.Parent.Update
	Next
Next
Message 10 of 13
roberto_infanti
Thanks!!!!!!!
Message 11 of 13
igorbenz
Hi Curtis, thank you very much for the help. May be I an not lucky but this rule do not updated all views, just some of them. Can you help me with update this rule please?
Message 12 of 13
igorbenz
It will be updated when I highlight views and push "Update" button in the left corner:
Message 13 of 13
igorbenz
Like this:
