Get Document Subtype (FrameGenerator, ContentCenter, Substitute, ...)
Hello
is it possible to get the documenttype of the following ipt-model files
(equal to the sheetmetal part, ...If DocumentObject.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}")
- ContentCenter Part
- Tube and Pipe Part
- Cable and harness part
- Frame Generator part
- Substitute part
we need it to fill in diffrent userproperties from/to our ERP system.
Thanks for any tips
Bruno
As of Inventor 2008, tube/pipe, cable/harness & Frame Generator stamp their
documents with "document interests", indicating that they have an "interest"
in a document. I've attached the list of interest names for such documents
as well as some sample code.
Substitute parts - PartDocument.IsSubstitutePart property returns this type.
Content center parts - Use the hidden ContentCenter.ContentCenterControlled
method.
Sanjay-
T&P
"Piping Runs Environment"
"Piping Run Environment"
"Piping Route Environment"
"Piping Hose Environment"
C&H
"HarnessPart"
"HarnessAssembly"
"NailboardDrawing"
Frame Generator
"FrameDoc" (Frame doc)
"SkeletonDoc" (Reference doc)
"FrameMemberDoc" (Frame Member doc)
Sub DocumentType()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim bIsRunDocument As Boolean
bIsRunDocument = oDoc.DocumentInterests.HasInterest("Piping Run
Environment")
End Sub
Hi Sanjay, just wondering if there was a set of constants for these defined in the API. Such as a DocumentInterestType?
Hi Josh,
No, there is not. Just the set of hard-coded strings.
Sanjay-
bradeneuropeArthur
I have used the additional propertysets for the filter!
For example the Content Center Files have 2 additional propertySets:
  • Content Library Component Properties
  • ContentCenter
The same for the other parts..
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
