Form format comes differently with another user
JohnBoySarcia
JohnBoySarcia
Hi, good day.
May I kindly ask why my form is showing differently on another user? On mine, all the tabs are aligned in columns, why on other users it's not. Is there some kind of set up thing that I need to check? Thanks
On my current laptop
On other user
bradeneuropeArthur
I have seen that with different monitors/screens.
In special when you use 4k monitors, and the scaling.
Don't use the 4 k settings but reduce the resolution, like:
is this the case with you?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JohnBoySarcia
We will try this, but in addition to my observation, somebody from our team saved another copy of that file and when I open it, we are seeing the same ilogic form format but when I open the original file that I've done, the ilogic form was good. Based on this observation, is there something in the CAD setup on their inventor creating that? Will let you know once I've checked each user's resolution.
A.Acheson
Hi @JohnBoySarcia
Are you positive you copied the same xml file? Maybe an old one still in use.  Although the layout is different the content is also different with different labels.
Good
Tab 2
"For Nozzles at top"
Bad
Tab 2
"For Nozzles at the bottom"
Regards
Alan
JohnBoySarcia
That's only my screenshot. But others are showing differently. Maybe I will try another approach instead of doing rows will do it in tabs as grouping it in columns rather than rows. Thanks for checking this out
JohnBoySarcia
We have tried and we have different settings, but settings don't affect the form when we unify it on the same settings.
For now this is close as I've try to use groups instead of rows
