copy all files form one folder to aother?
Darkforce_the_ilogic_guy
Advisor Advisor
I need to copy all files form
"C:\K-Tools\TempReviewPDF\",
 to
"H:\2e. Tegnestue\10. Drawing Review" & "\" & iProperties.Value("Project", "Part Number")
if the fil of the same name exists then go to next file or overrride
Michael.Navara
What kind of files you want to copy? It is just a PDF files or it is a files with references (like Inventor parts and assemblies)?
well it was pdf in this case , but I fix it with this code
	Try
	'	oLocalPath = "C:\K-Tools\TempReviewPDF"
	Dim FileList As String() = System.IO.Directory.GetFiles("C:\K-Tools\TempReviewPDF" , "*.*")
	'MsgBox(FileList)
	For Each f As String In FileList
		'MsgBox("Want to delete " & f)
		'System.IO.File.Copy(f,"H:\2e. Tegnestue\10. Drawing Review" & "\" & iProperties.Value("Project", "Part Number")+"\"+ Right(f,Len(f)-25))
		System.IO.File.Delete("H:\2e. Tegnestue\10. Drawing Review" & "\" & iProperties.Value("Project", "Part Number")+"\"+ Right(f,Len(f)-25))
	'Logger.Info(Right(f,Len(f)-25))
	Logger.Info(" Form " +f + " To " +"H:\2e. Tegnestue\10. Drawing Review" & "\" & iProperties.Value("Project", "Part Number")+"\"+ Right(f,Len(f)-25))
	Next
Catch' dirNotFound As DirectoryNotFoundException
	'MsgBox(dirNotFound.Message)
	Logger.Info("Fail to copy", filename)
End Try
	Try
	'MsgBox(FileList)
	Next
End Try
Michael.Navara
This code can be simplified and can work with any input and output directories
Dim sourceDir As String = "C:\Temp\Source\Files"
Dim targetDir As String = "C:\Temp\Target\Files"
Dim partNumber As String = iProperties.Value("Project", "Part Number")
Dim fullTargetDir = System.IO.Path.Combine(targetDir, partNumber)
System.IO.Directory.CreateDirectory(fullTargetDir)
Dim sourceFiles = System.IO.Directory.GetFiles(sourceDir, "*.*")
For Each sourceFile As String In sourceFiles
	Dim fileName = System.IO.Path.GetFileName(sourceFile)
	Dim targetFullFileName = System.IO.Path.Combine(fullTargetDir, fileName)
	System.IO.File.Copy(sourceFile, targetFullFileName, True)
Next
