Folder Saving
Folder Saving
Folder Saving
I have  a PDF iLogic code that batch saves all referenced drawings from the top level drawing.  the issue I am having is I would like to save the referenced drawings in their corresponding files but in my PDF folder(I save assemblies, sub assemblies, and parts in different folders). Currently they save in the top level assembly folder.  My code is attached below.
Thank you in advance.
cheers,
Josh
UPDATE:
I have them saving in the correct folders. although now they are creating a new folder for the drawings inside of the correct folder. While creating the folder it is leaving the PDF nameless.
Cheers,
Josh
MechMachineMan
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
should become something like:
oDataMedium.FileName = System.IO.Path.Combine(System.IO.Path.GetDirectoryName(oDoc.FullFileName), System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)) & ".pdf"
given that oDoc is the name of the file you are making a drawing of.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
