Flat Pattern to DXF
Flat Pattern to DXF
Flat Pattern to DXF
I now there are many version of this out there and that is where i got what I have so far.  My knowldege of coding is very limited and I don't have time now to learn but i really need this to work.
This code will give the the dxf but will no file name.  I would like it to have the same file name as the part # followed by -Revsion.
any help will be appreciated.
Thank you.
Frank
Sub FlatPatternDXF()
Dim oPartDoc As Document
Set oPartDoc = ThisApplication.ActiveDocument
' The Active document must be a part
If oPartDoc.DocumentType <> kPartDocumentObject Then
MsgBox "The Active document must be a 'Part'"
Exit Sub
End If
' The Active document must be a Sheet metal Part
If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox "The Active document must be a 'Sheet Metal Part'"
Exit Sub
End If
Dim oFlatPattern As FlatPattern
Set oFlatPattern = oPartDoc.ComponentDefinition.FlatPattern
' There must be a flat pattern
If oFlatPattern Is Nothing Then
MsgBox "Please create the flat pattern"
Exit Sub
End If
Dim oDataIO As DataIO
Set oDataIO = oPartDoc.ComponentDefinition.DataIO
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2000" _
+ "&OuterProfileLayer=OUTER_PROF&OuterProfileLayerColor=0;0;0" _
+ "&InteriorProfilesLayer=INNER_PROFS&InteriorProfilesLayerColor=0;0;0" _
+ "&FeatureProfileLayer=FEATURE&FeatureProfileLayerColor=0;0;0" _
+ "&BendUpLayer=BEND_UP&BendUpLayerColor=0;255;0&BendUpLayerLineType=37634" _
+ "&BendDownLayer=BEND_DOWN&BendDownLayerColor=0;255;0&BendDownLayerLineType=37634" _
Dim strProject As String
strProject = oPartDoc.PropertySets("Design Tracking Properties").Item("Project").Value
Dim strPath As String
strPath = "D:\Dropbox\Concept DXF\"
Dim oDXFfileNAME As String
oDXFfileNAME = strPath & strProject & ".dxf"
oDataIO.WriteDataToFile sOut, oDXFfileNAME
End Sub
MechMachineMan
Assuming that by revision you mean the revision number iProperty...
'config
    'Change values located here to change output.
    strPath = "C:\Users\Public\Documents\"  'Must end with a "\"
    Dim sOut As String
'/config
'Pre-processing check:
    ' The Active document must be a Sheet metal Part with a flat pattern
        Exit Sub
    Else
            Exit Sub
        Else
                Exit Sub
            End If
        End If
    End If
'Processing:
    Dim strPartNum As String
    strPartNum = oPartDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value
    Dim strRev As String
    strRev = oPartDoc.PropertySets("Inventor Summary Information").Item("Revision Number").Value
    oDXFfileNAME = strPath & strPartNum & "-R" & strRev & ".dxf"
    Call oDataIO.WriteDataToFile(sOut, oDXFfileNAME)
    'Toggle this on/off to open output folder during output.
    Call Shell("explorer.exe" & " " & strPath, vbNormalFocus)
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Much Thanks, that worked great.
JasonMayes
I have used a modified version of this code as a macro and it works great. I do have a question however... Is it possible to turn off holes up to a certain diameter and just leave center points? Here is the macro I am running currently. @Curtis_Waguespack
'config
strPath = "R:\email\" 'Must end with a "\"
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=Outer;IV_Arc_Centers&InvisibleLayers=IV_Tangent;IV_Bend;IV_Bend_Down;IV_Bend_Up"
'/config
Exit Sub
Else
Exit Sub
Else
Exit Sub
End If
End If
End If
'Processing:
oDXFfileNAME = strPath & strPartNum & ".dxf"
MsgBox "DXF has been created in R:\email"
'Call Shell("explorer.exe" & " " & strPath, vbNormalFocus)
End Sub
When I try to use this in Inventor 2018 it says that "let and set assignment statements are no longer supported, and that method arguments must be enclosed in parentheses.  I know nothing about code and if you know how to fix this it would be very helpful.
SometimesInventorMakesMeAngry
I think you were trying to paste the code into an iLogic rule, which uses VB.NET. You should paste it into a VBA module, which can be accessed via Inventor's VBA editor.
