Fixing the location of dimensions using i-Logic
ysbaodnj
Message 1 of 1
ysbaodnj
Hi everyone.
Currently, using the i-Logic code, the geometry is changed for each size, and the drawing is output.
I created the size and position of the view placed on the drawing without any problem, but the position of the dimension changes according to the size change.
The location of a dimension is determined by the lower left coordinates (0,0) and the upper right coordinates (1,1), regardless of the actual size of the model view.
For this reason, the 1's in views with different heights are not the same, so the position of the dimensions will continue to change as the size changes.
Is there any way to equalize these intervals?
Replies (0)
