iLogic to Create User Parameters
al.popovich
al.popovich
Good evening, Friends,
Is there an iLogic code that can create user parameters when they don't exist in a part or assembly file?
A simple example would be a file that currently has no user parameters created. The iLogic would then create user parameters named pThickness, pWidth, and pLength. If those parameters already exist they would be skipped. For our use, these would be numeric parameters.
Thank You,  Al
A.Acheson
Here is two samples. Sample 1 is just repetition of the same code so time consuming if you have many parameters.
Sample 2&3  is using a for loop to work with list/string array. Less code and less errors changing variable names.
Sample 1:
'Get the document
Dim Doc As Document = ThisDoc.Document
'Get the UserParameters collection.
Dim userParams As UserParameters = Doc.ComponentDefinition.Parameters.UserParameters
'Set Paramter Name
Dim ParamName1 As String = "pThickness"
Dim ParamName2 As String = "pWidth"
Dim ParamName3 As String = "pLength"
'Declare as parameter for later use
Dim Param1,Param2,Param3 As UserParameter
Try
	Param1 = userParams.Item(ParamName1)
Catch 'Parameter not found, so create it.
	Param1 = userParams.AddByValue(ParamName1, 0, UnitsTypeEnum.kMillimeterLengthUnits)
	'Param1.Value
End Try
Try
	Param2 = userParams.Item(ParamName2)
	Param2 = userParams.AddByValue(ParamName2, 0, UnitsTypeEnum.kMillimeterLengthUnits)
	'Param2.Value
End Try
Try
	Param3 = userParams.Item(ParamName3)
	Param3 = userParams.AddByValue(ParamName3, 0, UnitsTypeEnum.kMillimeterLengthUnits)
	'Param3.Value
End Try
 Sample:2  For loop with String Arrays.
'Get the document the rule is launched from.
'Declare as parameter for later use.
Dim Param As UserParameter
'Set Paramter Name Method 2: 1-dimensional string array.
Dim ParamList() As String = {"pThickness", "pWidth", "pLength" }
For Each ParamName In ParamList
	Try
		Param = userParams.Item(ParamName)
		Param = userParams.AddByValue(ParamName, 0, UnitsTypeEnum.kMillimeterLengthUnits)
		'Param.Value
	End Try
Next
Sample:3 For loop with List Of String.
'Set Paramter Name Method 1: List Of String.
Dim ParamList As New List(Of String)
ParamList.Add("pThickness")
ParamList.Add("pWidth")
ParamList.Add("pLength")
	Try
		'Param.Value
	End Try
Next
Regards
Alan
al.popovich
Thank You very much. I will try these options on Monday at the office.
Best Regards,  Al
drivasLL7NN
Muchas gracias!!! me ayudo mucho!!!
