Dimensional Constraint between sketchblocks
taher.basha
taher.basha
I want to create dimensional constraint between two sketchblocks as shown below pic using VB.Net or C#
and assign the userparameter to it. attaching the sample file
Michael.Navara
If you want to create dimension constraint between two blocks, you need to get appropriate geometry within the sketch. For this purpose there is a function GetObject. But you need to know which line it is in block definition.
Create dimension constraint sample
Sub AddDimensionConstraint()
    Dim activeSketch As PlanarSketch = ThisApplication.ActiveEditObject
    Dim blockA As SketchBlock = activeSketch.SketchBlocks(1)
    Dim blockB As SketchBlock = activeSketch.SketchBlocks(2)
    Dim line1Def As SketchLine = blockA.Definition.SketchLines(14) 'Use IndexOfLine to get this number
    Dim line1 = blockA.GetObject(line1Def)
    Dim line2Def As SketchLine = blockB.Definition.SketchLines(14) 'Use IndexOfLine to get this number
    Dim line2 = blockB.GetObject(line2Def)
    Dim textPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    activeSketch.DimensionConstraints.AddOffset(line1, line2, textPoint, False)
End Sub
Here is sample code how to get index of line in block definition sketch.
This code snippet expects you are in block definition sketch environment.
Sub IndexOfLine()
    Dim block As SketchBlockDefinition = ThisApplication.ActiveEditObject
    Dim pickedLine As SketchLine = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "sk line")
    Dim i = 1
    For Each skLine As SketchLine In pickedLine.Parent.SketchLines
        If (skLine Is pickedLine) Then
            Logger.Debug(i)
            Return
        i += 1
    Next
    Logger.Debug("not found")
End Sub
