Find BOMRow Parent Row object
Raider_71
Raider_71
Hi guys,
Am I missing something here? I need to check and then initiate the parent BOM row from the current one. So basically I need to iterate upward through the tree up to the root BOM node.
This is what I have done (which does not work)
    Function GetBOMTreeTotalQTY(oRow As Inventor.BOMRow, intQTY As Integer) As Integer
        Dim oParentRow As Inventor.BOMRow
        If oRow.Parent IsNot Nothing Then
            oParentRow = oRow.Parent()   <== This is where it fails
            GetBOMTreeTotalQTY(oParentRow, oParentRow.ItemQuantity * intQTY)
        Return intQTY
    End Function
Can someone please tell me how to grab the parent BOM row. The help doc says the "parent" property is to find the BOMView OR BOMRow object so I am not sure.
Any help would be appreciated.
Cheers
MechMachineMan
Hi.
As oParentRow is strongly typed, it will fail every time you run the code on a top BOMRow item as that would be trying to assign a BOMView to an object of type BOMRow.
Implement a check to see what type the .Parent is before assigning it to a strongly typed variable, or implement some error catching to handle such an issue.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
