Find and Create New iParts with Form and iLogic
At my company, we create a lot of duct banks that are MTO.  We are looking to reduce the time it takes to model them.
Currently, we have a multibody master file that holds a form to enter the specifics needed to create the plate as well as a few other things that change shape and size depending on the length and width of the plate.  It works great except that every time you run the generator, you get unique part numbers.  We would like to avoid having several part numbers for identical products.  Is there a way for Inventor/Vault to search vault for a plate that matches the specifications entered into the form and place it into the assembly or, if nothing exists, create a new plate?
My CAD lead thniks the answer lies with iParts.  While I believe using iParts and iAssemblies can get us a list of known parts that would help avoid duplicate parts, I don't know of a way to avoid having the process of looking through the 100's of options a reasonably fast one.
It sounds like a lot to ask of Inventor but, I thought if anyone has ran into this sort of thing, it's the good folks in the AutoDesk Inventor community.
bradeneuropeArthur
How could you check the uniqueness of parts within inventor.
Inventor will also see a rotated part as unique because of the different orientation.
If you would look at weight form and dimensions, maybe you will.
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Take a look at this.
Per accident today...
https://youtu.be/clFllo0zfHk
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
