Find a reference to layer, maybe ilogic could help?
Hunteil
Hunteil
I have a template with a layer I can't purge. I cleaned everything up, including Sketch Symbols, Title Blocks and Styles and checked for anything referencing this single layer... But it won't let me purge it still.
So I was thinking... can ilogic be used to find where these are referenced and replace them with the corresponding ANSI layer?
i.e.
"TITLE" with "Title (ANSI)"
PS: Yes I went to each object and changed the layer to Standard. So the only thing I can guess is it's referenced in the border some how.
Inventor: Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
Curtis_Waguespack
Hi @Hunteil
Did you look at Sheet Formats? I think that is a common thing to be hanging onto styles.
I hope this helps.
Curtis
Hunteil
I just deleted the sheet formats. Still can't purge.
Curtis_Waguespack
Hi @Hunteil
This will tell you if the layer is in cached local to the drawing, only in the library, or is in both... there might be some other info that can be reported that might help too if this doesn't help... I'll look at the API later to see if anything looks useful.I hope this helps.
Curtis
    'change this name as needed
oLayerName = "Sketch Geometry" Dim oLayer As Layer oLayer = ThisApplication.ActiveDocument.StylesManager.Layers.Item(oLayerName) oLocation = Replace(oLayer.StyleLocation.ToString, "k", "") oLocation = Replace(oLocation, "StyleLocation", "") MsgBox("Style location(both, local, or style library) : " & vbLf & oLocation)
