Filtering certain templates from a rule.
I have a rule that is meant to be ran from an assembly or weldment.  It goes through and identifies which parts are sheet metal, then it populates the custom iproperty 'SQFT' with the square feet the sheet metal's extents take up.  However, I have two templates for sheet metal.  I only want one of those templates to be affected by the rule.   Is there any thoughts on how to do this ? I've had some but I've failed to write a code that doesn't have errors (I'm a semi-beginner)
Here's my code so far:
		' Set the units for area:
		Dim UnitsMultiplier As Double
		' Want output in mm^2?
		'UnitsMultiplier = 1
		' Want output in cm^2?
		'UnitsMultiplier = 0.01
		' Want output in m^2
		UnitsMultiplier = 0.000001
		' Set the number of decimal places
		Dim DecimalPlaces As Integer = 2
        'check this file is an assembly
        Dim doc As Document = ThisApplication.ActiveDocument
            If doc.DocumentType = kPartDocumentObject Then
            MessageBox.Show("This rule can only be run in an assembly file!", "Cadline iLogic")
            Return
        Dim oCustomProps As Inventor.PropertySet
        Dim oProp As Inventor.Property
        Dim iCounter As Integer = 0
        ' Loop through all referenced docs in assembly
        For Each oDoc As Document In doc.AllReferencedDocuments
				If oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then ' It is a sheet metal part
                Dim oSP As PartDocument = CType(oDoc, PartDocument)
                Dim oDef As SheetMetalComponentDefinition = oSP.ComponentDefinition
                ' Check that a flat pattern exists on the part in question
                If IsNothing(oDef.FlatPattern) Then
                    Try ' Try unfolding part
                        oDef.Unfold()
                    Catch ' Failed to unfold part
                        MessageBox.Show("There is no flat pattern in " & oDoc.DisplayName & " - tried flattening and failed. Please open the file and create a flat pattern" ,"JACKRABBIT")
                        Continue For
                    End Try
                ' Get flat pattern
                Dim oFlatPattern As FlatPattern = oDef.FlatPattern
                ' Get face area
                Dim SheetMetalArea As Decimal = oFlatPattern.TopFace.Evaluator.Area
				' Get length and width
                Dim SheetMetalLength As Decimal = oFlatPattern.Length
                Dim SheetMetalWidth As Decimal = oFlatPattern.Width
				' Define custom iProperties
                oCustomProps = oDoc.PropertySets.Item("Inventor User Defined Properties")
                ' Create custom iProperty for the 'extents' area of the flat pattern (bounding rectangle area)
                Try ' Try setting value first
                    oCustomProps.Item("SQFT").Value = Math.Round(SheetMetalLength * SheetMetalWidth * 100 * UnitsMultiplier * 10.7639, DecimalPlaces)
                Catch ' Custom iProperty doesn't exist - so create it
                    oProp = oCustomProps.Add(Math.Round(SheetMetalLength * SheetMetalWidth * 100 * UnitsMultiplier * 10.7639, DecimalPlaces), "SQFT")
                End Try
        Next
bradeneuropeArthur
How are these two templates differentiated?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
They are both a sheet metal template.  One will always have the word 'Dakota' in the vendor iprop field.
WCrihfield
Since I still don't know which template you want this code to effect, and which template you don't want this code to effect, I just chose one to show you how.  I included the following 'check' just inside the loop, that looks at the Vendor iProperty value for that part, and if it 'Contains' the word "Dakota", I have it set to 'Continue For', which makes it skip to the next referenced document, without processing that part any further.
This is what that bit of code looks like:
'Check if this Sheet Metal Part has 'Dakota' in the Vendor iProperty value
If CStr(oPDoc.PropertySets.Item("Design Tracking Properties").Item("Vendor").Value).Contains("Dakota") Then
	'either continue or don't continue
	Continue For 'skip to next document in loop
Here's the whole code:
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
		MsgBox("An Assembly Document must be active for this rule to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
		Exit Sub
	Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
	For Each oDoc As Document In oADoc.AllReferencedDocuments
		'check if it is a Sheet Metal Part
		If oDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
		Dim oPDoc As PartDocument = oDoc
		Dim oSMDef As SheetMetalComponentDefinition = oPDoc.ComponentDefinition
	    If IsNothing(oSMDef.FlatPattern) Then
				oSMDef.Unfold()
				Continue For
			End Try
		'Get flat pattern
		Dim oFlatPattern As FlatPattern = oSMDef.FlatPattern
		'Get face area
		'Get length and width
		'Define custom iProperties
		oCustomProps = oPDoc.PropertySets.Item("Inventor User Defined Properties")
		'Create custom iProperty for the 'extents' area of the flat pattern (bounding rectangle area)
		End Try
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you have time, please... Vote For My IDEAS 💡or you can Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
@WCrihfield
I tried that code at the assembly level, and it still filled the SQFT value in both parts, even though, only one of them has 'Dakota' written in the 'Vendor' field.  Both templates are a sheet metal template, only difference is that one will have different iproperty values filled out on it, as the other will be mostly empty to start with.
Just noticed that I have the word capitalized.  Now it worked !. Thank you !
bradeneuropeArthur
Good to hear that it is solved!
To solve upper an lowercase:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
