Auto-Export a DXF to a file location.
Hi, I've been having trouble finding a good code for a rule that exports a 2004 DXF from a part file.  I have a config file that contains all the export information.  I'd like to name the file as the parts custom iproperty 'Item Code'.  Lastly, I'd like to save it in a specific file location. (I'll eventually make this rule a ribbon button using vba.)
Any help is appreciated !
bhavik4244
@Anonymous
Some time ago I wrote a post on Clint Brown's unofficial inventor Blog for exporting the dxf file and save it at desired location with their iPart member name. Here is a link for that.
You can modify a bit, for example, change the location, change the file name as iproperties instead of ipart member name. by that you may achieve what you're looking for.
Bhavik Suthar
