Referencing a custom iProperty from a drawing.
Hi, I am trying to create a ribbon button on a drawing to export the drawing as a PDF to a location and name the PDF as a custom iproperty that is contained in the part file.
My code right now pulls the iproperty from the drawing called "Part Number".  I want it to pull a custom iproperty from the part called "Item Code".
Here's my code which is almost complete:
DrawingName = iProperties.Value("Project", "Part Number")
DesiredPath = "C:\JACKRABBIT\INVENTOR TEMPLATES 2022\MISC\PDF"
NewFileName = DesiredPath & "\" & DrawingName & ".pdf"
'check file name to see if it is used
	'if it is, ask the user to overwrite
	'if it's not, save the file
question = MessageBox.Show("Is this a good file name?:  " & DrawingName & ".pdf", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If question=vbYes Then
	If System.IO.File.Exists(NewFileName) Then
		question = MessageBox.Show("File exists, do you want to overwrite?", "iLogic Question",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
			If question = vbYes Then
				System.IO.File.Delete(NewFileName)
				ThisDoc.Document.SaveAs(NewFileName, True)
			Else If question =vbNo Then
				MessageBox.Show("File was not overwritten", "iLogic Message")
	Else
Else If question=vbNo Then
	MessageBox.Show("Please fix Part Number")
bhavik4244
@Anonymous
This code can solve your issue.
Sub Main
DrawingName = iProperties.Value("Custom", "Item Code")
'				ThisDoc.Document.SaveAs(NewFileName, True)
				Call export_PDF
				Call export_PDF
	Else
		Call export_PDF
End Sub
Function export_PDF()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
         PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    Dim oDocument As Document    ' a reference to the active document (the document to be published).
         oDocument = ThisApplication.ActiveDocument
    Dim cdoc As Inventor.Document
         cdoc = ThisApplication.ActiveDocument
	DrawingName = iProperties.Value("Custom", "Description")
    Dim Fname As String
        Fname = cdoc.FullFileName
    Dim Name As String
        'name = Left(Fname, Len(Fname) - 4) & "\PDF" & ".pdf"
        Name = DrawingName & ".pdf"
    Dim oContext As TranslationContext
         oContext = ThisApplication.TransientObjects.CreateTranslationContext
        oContext.Type = kFileBrowseIOMechanism
    Dim oOptions As NameValueMap ' Create a NameValueMap object
         oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    Dim oDataMedium As DataMedium ' Create a DataMedium object
         oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then ' Check whether the translator has 'SaveCopyAs' options
MessageBox.Show(Name, "Title")
    ' Options for drawings...
        oOptions.Value("All_Color_AS_Black") = 0
        'oOptions.Value("Remove_Line_Weights") = 0
        oOptions.Value("Vector_Resolution") = 1200
        oOptions.Value("Sheet_Range") = kPrintAllSheets
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    oDataMedium.FileName = Name '& "\" & "PDF" & "\" ' the destination file name"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Function
Bhavik Suthar
This line of code refers to the custom iproperty 'Item Code' within the drawing, but I need the custom iproperty 'Item Code'  that is in the part file.
bhavik4244
@Anonymous
Here you go 🙂
Sub Main
docname = ThisDoc.FileName(False) 'without extension
oModelDoc = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
ItemNumber = iProperties.Value(oModelDoc, "Custom", "Item Code")
MessageBox.Show(ItemNumber, "Item Code")
				Call export_PDF
				Call export_PDF
	Else
		Call export_PDF
End Sub
    Dim Fname As String
    Dim Name As String
        Name = ItemNumber & ".pdf"
    'Publish document.
End Function
Bhavik Suthar
