iLogic Get Model Sketches to Drawing View
jkorson
Message 1 of 33
jkorson
My goal is to get a iLogic rule to "Get Model Sketches" from my drawing view and to "Include" it in my view. I'm not quite sure how to do this.
I have looked at similar forums but I cannot manipulate the code enough for it to work. Here are the forums that I tried:
Get Model Sketches - Autodesk Community - Inventor
Include/Exclude or Visibility on/off : Model sketches in drawing views. - Autodesk Community - Inven...
I'm working in Inventor 2021.
Replies (32)
Message 2 of 33
dutt.thakar
@jkorson
Can you upload your file, I can try to create/modify the existing code for you to make it work for your application. I can create an example for the test, but I am not sure whether that will be the same thing you are looking for or not. If you can upload some files with the similar requirements that you are trying to achieve I could help you by creating an iLogic that will serve your purpose.
Hope this will help you.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
Message 3 of 33
jkorson
I attached the documents. My rule lives in the "FAB-DRAWING.dwg" called "get model sketch".  I'm trying to show the "CUT PROFILE" sketch on my view in FAB-DRAWING.dwg file.
Message 4 of 33
dutt.thakar
@jkorson
Can you try the below code and see if this works? Please note that the proxy is only applicable when you work with assemblies, whenever you work with part files, there is no need of proxies.
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisDoc.Document
oView = oDrawingDoc.ActiveSheet.DrawingViews(1)
Dim oPart As PartDocument
oPart = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oPartDef As PartComponentDefinition
oPartDef = oPart.ComponentDefinition
Dim oSketch As PlanarSketch
For Each oSketch In oPartDef.Sketches
	If oSketch.Name = "CUT PROFILE"                ' I have explicitly added the name of sketch here
	oView.SetIncludeStatus(oSketch,True)
	oView.SetVisibility(oSketch, True)
Next
Dutt Thakar
LinkedIn
Message 5 of 33
jkorson
Thank you  @dutt.thakar for helping. I greatly appreciate it! The code preformed as expected.
Message 6 of 33
m.den.ouden
even better code
Public Sub IncludeSketch(oView As DrawingView, SketchName As String, Optional Include As Boolean = True, Optional Visible As Boolean = True)
	Dim oPartDocument As PartDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
	Dim oPartComponentDefinition As PartComponentDefinition = oPartDocument.ComponentDefinition
	Try
		Dim oSketch As PlanarSketch = oPartComponentDefinition.Sketches.Item(SketchName)
		oView.SetIncludeStatus(oSketch, Include)
		oView.SetVisibility(oSketch, Visible)
	Catch
		MsgBox(SketchName + "Doesn't Exist")
	End Try
End Sub
Message 7 of 33
froschhaeuserkonstruktion
Hello all,
this codes works even fine for me. But now i have the special case that i want to show a sketch from a flat pattern in the drawing view. Is that even possible?
With your code i get the sketch from the folded model but not from the flat pattern
thanks in advance
Message 8 of 33
m.den.ouden
What is it you want to achieve? And maybe you can send a file of printscreen with some notes
Message 9 of 33
I have to add some marks and text on the flat pattern for our manufacturer.
This marks varies from part to part.
For now i have some code that automatically generates a drawing view for flat pattern and exports it to dxf. So adding this sketches manualy in the drawing is not an option
Message 10 of 33
m.den.ouden
what do you want to use the marks for? do you want to create dimensions?
Message 11 of 33
m.den.ouden
You could send me the file with notes and I can program it for you.
Message 12 of 33
Here are the files, created in Inventor 2022
Message 13 of 33
thanks a lot in advance
Message 14 of 33
m.den.ouden
okay thanks. I install 2022 then upfront cause I use 2023
Message 15 of 33
2023 is fine for me. I got both installed so I can copy the code out of 23 to 22
Message 16 of 33
m.den.ouden
can you maybe provide me a formula to calculate the unfolded width?
Message 17 of 33
jkorson
@m.den.ouden You can go into your iLogic snippets and retrieve your flat extents width and length.  It's under the Sheet Metal folder.
Message 18 of 33
m.den.ouden
Oh that means I can retrieve it in the API it self. I'll look for it myself.
Message 19 of 33
m.den.ouden
all right that did the trick
Message 20 of 33
m.den.ouden
There is one big problem with the flatpattern to create dimensions a great steady simple way. In the flatpattern you can not create named geometry. I can acces the faces and edges through the API with iLogic in SheetMetalComponentDefinition.FlatPattern.Body and then assign a name. but the pop up in the unfolded section in a weird place and now I can't retrieve them in the unfolded view with this line of code.
Dim oNamedEntities = iLogicAuto.GetNamedEntities(oDoc)
So now I had to work with workpoints (or planes and axis)
