filename without extension in the BOM
eladm
Message 1 of 18
eladm
Hi All
I need to add file name column in BOM / Part list . The default is with the file extension ipt/iam
I need only the file name
this rule:
File_Name = iProperties.Value("Project", "Part Number")
 iProperties.Value("Custom", "File Name" ) = Split(File_Name, ".")(0)
 create iproperties in the main file with my goal ,
How I can run this code from the assembly to all the parts and sub-assembly
best regards
Replies (17)
Message 2 of 18
bradeneuropeArthur
You don't need coding for this.
Create a user defined property
FileName   with =<Part Number>
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 18
eladm
Hi
Part number not equal to file name
Message 4 of 18
bradeneuropeArthur
how does your partnumber look like.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 18
eladm
After save the file I change the part number field to other value , not all the file (bolts for example) but the part number is change
regards
Message 6 of 18
bradeneuropeArthur
For VBA:
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As AssemblyDocument
Set b = a.ActiveDocument
loopass (b)
End Sub
Public Sub loopass(b As AssemblyDocument)
Dim o As ComponentOccurrence
Dim doc As Document
Dim c As PartDocument
Dim File_Name As String
Dim FileName As String
For Each o In b.ComponentDefinition.Occurrences
MsgBox o.Name
doc = o.Definition.Document
File_Name = doc.PropertySets.Item(3).Item("Part Number").Value
If doc.DocumentType = kPartDocumentObject Then
On Error Resume Next
doc.PropertySets.Item(4).Add Split(File_Name, ".")(0), "File Name"
doc.PropertySets.Item(4).Item("File Name").Value = Split(File_Name, ".")(0)
ElseIf doc.DocumentType = kAssemblyDocumentObject Then
On Error Resume Next doc.PropertySets.Item(4).Add Split(File_Name, ".")(0), "File Name" doc.PropertySets.Item(4).Item("File Name").Value = Split(File_Name, ".")(0) loopass (doc) End If o.Definition.Document Next End Sub
For i-logic:
Public Sub main()
a = ThisApplication
loopass (b)
End Sub
Dim doc As Document
MsgBox o.Name
try
doc.PropertySets.Item(4).Add (Split(File_Name, ".")(0), "File Name")
Catch exception
end try
try
catch exception
end try
loopass (doc)
End If
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 18
eladm
Hi , sorry  ,I-logic not working
Message 8 of 18
bradeneuropeArthur
Public Sub Main()
 a = ThisApplication
loopass (b)
End Sub
Dim doc As Document
'MsgBox(doc.PropertySets.Item(4).Item("File Name").Value)
loopass (doc)
End If
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 18
eladm
Hi
The result is part number , I need the file name
the file ilogic_test.ipt have part number eeee , the result of the rule is part number
if part added to the assembly or the part number changed , run rule failed
Error in rule: Rule0, in document: Assembly1
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Message 10 of 18
bradeneuropeArthur
You gave us this:
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 18
eladm
Hi
Sorry , it was just of an example i found in the internet, the goal is too get a column in BOM of filename without extension and some of the files the file name and part number is not equal
best regards
Message 12 of 18
bradeneuropeArthur
Hope that this is what you need.
Are you a bit familiar with coding?
Public Sub Main()
 a = ThisApplication
loopass (b)
End Sub
Dim doc As Document
'File_Name = doc.FileName(False)
doc.PropertySets.Item(4).Add (doc.FileName(False), "File Name")
doc.PropertySets.Item(4).Item("File Name").Value = doc.FileName(False)
loopass (doc)
End If
Next
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 18
eladm
Hi
I know only basic thing
the code not working
Error in rule: Rule0, in document: del.iam
Public member 'FileName' on type 'PartDocument' not found.
Message 14 of 18
tonythm
Please try for VBA:
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
       oDoc.DisplayName
If you get full file name, please try: oDoc.FullFileName
Message 15 of 18
k14348
    Hope your issue resolved.
-Karth
Option Explicit
Sub CustomProp()
    Dim oDoc As AssemblyDocument
    Dim oRefDoc As DocumentsEnumerator
    Set oRefDoc = oDoc.AllReferencedDocuments
    Dim oPartDoc As PartDocument
    Dim i As Integer
    For i = 1 To oRefDoc.Count
    Dim oDisp As String
    oDisp = oRefDoc.Item(i).DisplayName
    Dim textValue As Variant
    textValue = oDisp
    Dim oFile As String
    oFile = "FileName"
    Dim oCProp As PropertySet
    Set oCProp = oRefDoc.Item(i).PropertySets.Item("Inventor User Defined Properties")
    Dim oProp As Property
    Set oProp = oCProp.Add(textValue, oFile)
    Next
End Sub
Message 16 of 18
WCrihfield
Here is the short & simple code I use for this in an external iLogic rule.
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oCustPropSet As PropertySet
Dim oPropName As String = "File Name Without Extension"
Dim oPropValue As String
Dim oExists As Boolean = False
Dim oProp As [Property]
For Each oRefDoc As Inventor.Document In oADoc.AllReferencedDocuments
	oCustPropSet = oRefDoc.PropertySets.Item("Inventor User Defined Properties")
	oPropValue = IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName)
	For Each oProp In oCustPropSet
		If oProp.Name = oPropName Then oExists = True
		oOverwrite = MsgBox("Property already exists. Overwrite its value?", vbYesNo + vbQuestion, "PROPERTY EXISTS")
		If oOverwrite = vbNo Then Return
		oProp.Value = oPropValue
	Next
	If oExists = False Then
		oProp = oCustPropSet.Add(oPropValue, oPropName)
	End If
Next
You can put this external iLogic rule in the Event Triggers dialog / Assemblies tab / Before Save Document (and/or under Any Model parameter Change, if they effect which components are present.)  Then those properties will always be available in your assemblies, right after you click save.  Then all you have to do is open your BOM, then click the "Add Custom iProperty Column", and select this new property.  Or you can simply save this BOM columns customization within your Assembly template file.
Hope this helps.
Wesley Crihfield
(Not an Autodesk Employee)
Message 17 of 18
WCrihfield
Correction:  a line of code didn't get copied over when I posted before.
Also, it it seems some folks may have trouple with the two question lines, so I added an additional declaration to help cover that possible error.
You'll also notice that I commented out the question lines (that's how I usually use it), because it's really annoying when you have a ton of components in the assembly, and you don't care if it overwrites that data.
iProperties.Value("Custom",oPropName) = IO.Path.GetFileNameWithoutExtension(oADoc.FullFileName)
Dim oOverwrite As MsgBoxResult
'		oOverwrite = MsgBox("Property already exists. Overwrite its value?", vbYesNo + vbQuestion, "PROPERTY EXISTS")
'		If oOverwrite = vbNo Then Return
	Next
	End If
Next
If this solves your problem, or answers your question, please click 'Accept As Solution'.
Or if this helps anyone out, towards reaching your goals, pleas click 'Likes' 👍.
Wesley Crihfield
Message 18 of 18
maxim.teleguz
c = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select component")
If c Is Nothing Then
		Exit Sub
	Else
		'get the path and file name of the selected item
		d = Component.InventorComponent(c.name).Definition.Document.FullFileName
		f = IO.Path.GetFileNameWithoutExtension(d)
		MsgBox(f)
		'exit sub
	End If
this should solve it for everyone going forward, the easiest way possible
