File Naming Defaults API access
mjordan2
mjordan2
Is there API access to the "File Naming Defaults" application options for 2019?  (Much like Application.FileOptions, or Application.AssemblyOptions.)  I looked through the Application object in the Inventor API reference but didn't see anything.
Thanks much!
bradeneuropeArthur
Could you please explain a little more...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
mjordan2
Sure thing...
I can directly set Inventor's Application Options like so from iLogic:
ThisApplication.GeneralOptions.UserName = "Bob Hope"
ThisApplication.FileOptions.TemplatesPath = "Server\\CAD\Inventor Templates"
ThisApplication.ContentCenterOptions.SetAccessOption(kInventorDesktopAccess,"Server\\Cad\Inventor\2019 Content Center Libraries\")
Right now I've got a routine that sets my user's options as needed.  I'd like to add the new Frame Generator File Naming Defaults included in Inventor 2019 to my script, but didn't know if those options were exposed via the iLogic API yet.
Thanks!
chandra.shekar.g
Autodesk Support
Autodesk Support
@mjordan2,
There is already a change request(INVGEN - 23282) with Engineering team on this.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
