File Dialog for folder selection
Message 1 of 11
I want to use the inventor file dialog to allow the user to navigate to select a folder.
I know I could use a windows folder dialog, but I prefer the interface of the file dialog.
You can do this using the windows file dialog by using a filter of "*.none" and then extracting the directory from the filename once the dialog "open" is pressed:
Using obj As New Windows.Forms.OpenFileDialog
obj.Filter = "Directories|*.none"
obj.CheckFileExists = False
obj.CheckPathExists = False
obj.InitialDirectory = startPath
obj.Title = "Select Save Directory"
obj.FileName = "Save Directory"
If obj.ShowDialog = Windows.Forms.DialogResult.OK Then
savePath = IO.Directory.GetParent(obj.FileName).FullName
'can extract directory from savePath
End If
End Using
Is there a way to do this with the inventor file dialog? I'd prefer to use the inventor file dialog because it already includes links to the work space and thumbnails etc.
Accepted solutions (4)
Replies (10)
Message 2 of 11
Jesper_S
Hi.
I'm not a master coder in iLogic but found this some time ago here in the forum.
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'oFileDlg.InitialDirectory = sPath 'currently doesn't work
oFileDlg.CancelError = True
oFileDlg.MultiSelectEnabled = True
'oFileDlg.ShowQuickLaunch = True
' Define the filter to select files
oFileDlg.Filter = "Inventor Drawing Files (*.idw;*.dwg)|*.idw;*.dwg"
' Set the title for the dialog.
oFileDlg.DialogTitle = "Choose the files to work with."
On Error Resume Next
'oFileDlg.ShowSave()
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
Return
ElseIf oFileDlg.FileName <> "" Then
selectedfiles = oFileDlg.FileName
End If
Hope you can use some of it.
//Jesper
//Jesper
Message 3 of 11
Thanks Jesper, but that is not quite what I am after.
That is to open or save a file, I would like to use the same dialog however just to get the folder not a file.
Message 4 of 11
Sergio.D.Suárez
Imports System.Windows.Forms
' Toma la ruta del archivo activo Dim RutaExport As String = ThisDoc.Path ' Define el cuadro de dialogo de busqueda de carpeta Dim Dialog = New FolderBrowserDialog() ' Establece opciones del cuadro de dialogo Dialog.SelectedPath = RutaExport Dialog.ShowNewFolderButton = True Dialog.Description = "Elige la carpeta de exportación" ' muestra el cuadro de dialogo If DialogResult.OK = Dialog.ShowDialog() Then ' captura la ruta de exportacion seleccionada RutaExport = Dialog.SelectedPath & "\"
MessageBox.Show(RutaExport, "Title")
late but sure, try this code greetings
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 5 of 11
Try this one:
Function BrowseForFolder(Optional OpenAt As Variant) As Variant
     'Function purpose:  To Browser for a user selected folder.
     'If the "OpenAt" path is provided, open the browser at that directory
     'NOTE:  If invalid, it will open at the Desktop level
    Dim ShellApp As Object
     'Create a file browser window at the default folder
    Set ShellApp = CreateObject("Shell.Application"). _
    BrowseForFolder(0, "Please choose a folder", 0, OpenAt)
    If ShellApp Is Nothing Then
        BrowseForFolder = ""
        Exit Function
    End If
     'Set the folder to that selected.  (On error in case cancelled)
    BrowseForFolder = ShellApp.self.Path
    On Error GoTo 0
     'Destroy the Shell Application
    Set ShellApp = Nothing
     'Check for invalid or non-entries and send to the Invalid error
     'handler if found
     'Valid selections can begin L: (where L is a letter) or
     '\\ (as in \\servername\sharename.  All others are invalid
    Select Case Mid(BrowseForFolder, 2, 1)
    Case Is = ":"
        If Left(BrowseForFolder, 1) = ":" Then GoTo Invalid
    Case Is = "\"
        If Not Left(BrowseForFolder, 1) = "\" Then GoTo Invalid
    Case Else
        GoTo Invalid
    End Select
    Exit Function
Invalid:
     'If it was determined that the selection was invalid, set to False
    BrowseForFolder = False
End Function
Message 6 of 11
skatzY7HV8
Did this question ever get answered? I tried the code in the latest post and it still gives the unfriendly windows folder browser
Message 7 of 11
Curtis_Waguespack
Hi @skatzY7HV8
This would be rather clunky, but you could have the user select a file, and just get the parent directory of that file, as in this example. Otherwise I don't know of a way, other than to use the "unfriendly" version to browse for a folder.
I hope this helps.
Curtis
Dim oFileDlg As Inventor.FileDialog = Nothing
oFileDlg.Filter = "Inventor Files (*.iam;*.ipt)|*.iam;*.ipt|All Files (*.*)|*.*"
oFileDlg.DialogTitle = "Choose a file in the folder you are trying to get."
oFileDlg.ShowOpen()
Return
oFolder = System.IO.Path.GetDirectoryName(oFileDlg.FileName)
End If
MsgBox(oFolder)
Message 8 of 11
skatzY7HV8
Curtis,
Thanks for the reply - that will work for me as a faster method allowing shortcuts to be used. Maybe one day there will be a better select folder dialog out of the box.
Stephen
Message 9 of 11
dvinalsauc
buen codigo amigo. Solo te falto el End If.
Una pregunta, sabrias como hacer un codigo para insertar un assembly o part desde un Browse Windows? Lo que normalmente haria con un simple PLACE, pero quiero agregar unas cuantas funciones
Message 10 of 11
william
Hi, I was looking for this recently and found the below to work quite well.
OpenAt = "your starting location"
Dim dialog = New FolderBrowserDialog()
dialog.SelectedPath = OpenAt
If DialogResult.OK = dialog.ShowDialog() Then
	MessageBox.Show(dialog.SelectedPath, "Title")
End If
Message 11 of 11
tim11_manhhieu
thank you so much.
