Flat Extents Precision Format
DewayneH
DewayneH
I have been working on a sheet metal rule to get the flat extents. I found some code that does exactly what I need except it is formatted as a fraction.
I figured with a little research I could figure out how to change the formatting to what I need. I failed miserably.
The best I can do is remove the rounding function shown. Once removed, I get a value to six decimal places and leading zeros (0.980178).
Is there a way to format the "SheetMetal.FlatExtentsLength" and "SheetMetal.FlatExtentsWidth" as a formatted decimal or text, instead of a fraction?
I just need three decimal places and suppress the leading zeros.
LengthFrac = RoundToFraction(SheetMetal.FlatExtentsLength, 1/16, RoundingMethod.Round)
WidthFrac = RoundToFraction(SheetMetal.FlatExtentsWidth, 1/16, RoundingMethod.Round)
Dewayne
Inventor Pro 2023
Vault Pro 2023
Jesper_S
Hi.
How about
LengthFrac = Round(SheetMetal.FlatExtentsLength, 3)
WidthFrac = Round(SheetMetal.FlatExtentsWidth, 3)
 //Jesper
//Jesper
DewayneH
That does work for rounding, but unfortunately I didn't want to round.
I would like to just show the precision at three decimals, and suppress leading zeros.
Is there maybe a reference that shows the proper way and options for formatting the parameter, like this?
Dewayne
Inventor Pro 2023
Vault Pro 2023
bradeneuropeArthur
Export it to a parameter.
Then you can customise the parameter value with the format you need.
If further explanation is required please let me know.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
This is how:
and dot that also for the other parameter.
Parameter.Param("LengthFrac").Value = SheetMetal.FlatExtentsLength
Parameter.Param("LengthFrac").Precision = 3
Parameter.Param("LengthFrac").ExposedAsProperty = True
Parameter.Param("LengthFrac").CustomPropertyFormat.ShowLeadingZeros = False
Parameter.Param("LengthFrac").CustomPropertyFormat.ShowTrailingZeros = False
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
DewayneH
I was trying to get around adding more users parameters, but it is simpler this way.
Thanks.
Dewayne
Inventor Pro 2023
Vault Pro 2023
