Export Inventor Parameters to notes
abhay.gilka
abhay.gilka
I am trying to add some conversion formulas in parameters through prompted entry and bring them to the inventor drawing notes. If there are alternate ways to achieve the main objective which is creating a general note on prompted entry and converts to simple multiplication or division formula is good as well.
Appreciate some innovative ideas.Thanks!
bradeneuropeArthur
Do you need the formulas orchestra expresions/values.
If yes.
Export them as property and add them to the note as custom property text.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
abhay.gilka
Appreciate if you could share some example using inventor file for reference..thanks!
