Here it is @bradeneuropeArthur (it obviously makes several other things as well....)
Dim drawing As DrawingDocument = ThisDoc.Document
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim PRIMERA_LINEA As String
PRIMERA_LINEA = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("PRIMERA LINEA").Value)
Dim SEGUNDA_LINEA As String
SEGUNDA_LINEA = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("SEGUNDA LINEA").Value)
Dim DISEÑADOR As String
DISEÑADOR = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("DISEÑADOR").Value)
Dim NUMERO_MODULO As String
NUMERO_MODULO = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("NUMERO MODULO").Value)
Dim CODIGO_TECNICO As String
CODIGO_TECNICO = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("CODIGO TECNICO").Value)
Dim TIPO_DE_PLANO As String
TIPO_DE_PLANO = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("TIPO DE PLANO").Value)
Dim NUMERO_PLANO As String
NUMERO_PLANO = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("NUMERO PLANO").Value)
Dim NUMERO_INSTALACION As String
NUMERO_INSTALACION = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("NUMERO INSTALACION").Value)
Dim CODIGO_DE_PARTICION As String
CODIGO_DE_PARTICION = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("CODIGO DE PARTICION").Value)
Dim NOMBRE_DE_CLIENTE As String
NOMBRE_DE_CLIENTE = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("NOMBRE DE CLIENTE").Value)
Dim TIPO_DE_INSTALACION As String
TIPO_DE_INSTALACION = CStr(oDoc.PropertySets.Item("Inventor User Defined Properties").Item("TIPO DE INSTALACION").Value)
Dim oPList As PartsList = Nothing
For Each oList As PartsList In oDoc.ActiveSheet.PartsLists
If oList.Title IsNot Nothing Then
oPList = oList
Exit For
End If
Next
If oPList Is Nothing Then
MsgBox("No hay una lista de materiales en la hoja activa.", MessageBoxIcon.Exclamation, "No hay lista de materiales")
Return
GoTo es
End If
Dim partsList As PartsList = drawing.ActiveSheet.PartsLists(1)
Dim bomFileName = ThisDoc.PathAndFileName(False) & ".xlsx"
Dim Template = "C:\Users\Public\VAULT\Inventor Libraries\Templates\223500_Template.xlsm"
'____________________________________________
drawing = ThisApplication.ActiveDocument
'If Err.Number <> 0 Then
' MsgBox("No existe una lista de materiales en el dibujo." & vbCrLf & vbCrLf & "Debes crear una lista de materiales antes de ejecutar la BOM.", MessageBoxIcon.Exclamation, "No hay lista de materiales")
' GoTo fin
'End If
If ThisDoc.PathAndFileName() = Nothing Then
MsgBox ("Debes guardar el documento primero.",MessageBoxIcon.Exclamation,"No existe el fichero")
GoTo fin
End If
Excelapp = CreateObject("Excel.application")
Excelapp.visible = False
Excelapp.DisplayAlerts = False
excelworkbook = Excelapp.workbooks.add(Template)
'excelworkbook = Excelapp.worksheets("DatosD").delete
'excelworkbook = Excelapp.worksheets.add("DatosD")
Dim bomNameChanged As String = ThisDoc.FileName(False)
bomNameChanged = bomNameChanged.Replace("X", "N")
bomNameChanged = bomNameChanged.Replace("Z", "N")
bomNameChanged = bomNameChanged.Replace("P", "N")
bomNameChanged = bomNameChanged.Replace("x", "N")
bomNameChanged = bomNameChanged.Replace("z", "N")
bomNameChanged = bomNameChanged.Replace("p", "N")
bomNameChanged = bomNameChanged.Replace("n", "N")
Dim bomNameChangedTwice As String = bomNameChanged & ".xlsx"
Dim bomFinalName As String = String.Concat(ThisDoc.Path, "\", bomNameChangedTwice)
excelworkbook.saveas(bomFinalName)
excelworkbook.close
Excelapp.quit
'Options
'Name Value Type Valid For export formats
'TableName String kMicrosoftExcel, kMicrosoftAccess
'ExportedColumns String containing semicolon separated column titles All
'IncludeTitle Boolean kMicrosoftExcel, kTextFileCommaDelimited, kTextFileTabDelimited, kUnicodeTextFileCommaDelimited, kUnicodeTextFileTabDelimited
'StartingCell String kMicrosoftExcel
'Template String kMicrosoftExcel
'AutoFitColumnWidth Boolean kMicrosoftExcel
Dim options As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
options.Value("TableName") = "DatosD"
options.Value("StartingCell") = "A1"
'options.Value("Template") = bomNewName
folderName = ThisDoc.Path
partsList.Export(bomFinalName, PartsListFileFormatEnum.kMicrosoftExcel, options)
'Add additional info
Dim fileName As String = ThisDoc.FileName(False)
fileName = fileName.Replace("X", "N")
fileName = fileName.Replace("Z", "N")
fileName = fileName.Replace("P", "N")
fileName = fileName.Replace("x", "N")
fileName = fileName.Replace("z", "N")
fileName = fileName.Replace("p", "N")
fileName = fileName.Replace("n", "N")
GoExcel.Open(bomFinalName, "BOM")
'GoExcel.CellValue("H5") = fileName
GoExcel.CellValue("F4") = PRIMERA_LINEA
GoExcel.CellValue("F5") = SEGUNDA_LINEA
GoExcel.CellValue("K3") = DateTime.Now.Date
GoExcel.CellValue("K4") = DISEÑADOR
'GoExcel.CellValue("M3") = NUMERO_MODULO
'GoExcel.CellValue("N3") = CODIGO_TECNICO & "-" & TIPO_DE_PLANO & "-" & NUMERO_PLANO
'GoExcel.CellValue("F2") = NUMERO_INSTALACION & "-" & CODIGO_DE_PARTICION
GoExcel.CellValue("F3") = NOMBRE_DE_CLIENTE & " - " & TIPO_DE_INSTALACION
GoExcel.Save
GoExcel.Close
go = MessageBox.Show("¿Quiere abrir el archivo?", FileName(False) & ".xlsx", MessageBoxButtons.YesNo)
If go = 6 Then ThisDoc.Launch(bomFinalName)
GoTo fin
es :
GoTo fin
fin :
