ExpertMode?
ExpertMode?
mikazakov
ExpertMode?
mikazakov
UserInterfaceManager.ExpertMode is "Text off" of Inventor user?
see attaced screen-shot
MechMachineMan
Test it out and get back to us?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
mikazakov
I cant understand your question.
I tried do ExpertMode=true and ExpertMode=false. I did not see, that AI change his behavior of user interface.
mikazakov
Thу ExpertMode probably the classic interface, which existed before the Ribbons. API's help very brief, it is very difficult to guess.
