Exclude a sheet from print if a certain condition is met
anthony.alam
anthony.alam
Hello, i am heaving difficulties with iLogic.
i wrote a rule in a drawing that checks a certain parameter, and if conditions are met it excludes a sheet from count and print.
but it does not seem to work.
here is the code:
oDoc= ThisApplication.ActiveDocument
Dim oSheet As Sheet
'If ActiveSheet.Name = "Jamb_typeG"
If Parameter("D1.ipt.f1_type") < 5 mm Then
For Each oSheet In oDoc.Sheets
If (ActiveSheet.Name = "Jamb_typeG") Or (ActiveSheet.Name = "Jamb_typeG:2")
oSheet.ExcludeFromCount = True
oSheet.ExcludeFromPrinting = True
If (ActiveSheet.Name = "Jamb_typeM") Or (ActiveSheet.Name = "Jamb_typeM:2")
oSheet.ExcludeFromCount = False
oSheet.ExcludeFromPrinting = False
Next
MechMachineMan
Because your stringing together things that aren't making consistent variable calls.
If you are iterating through sheets and wanting the loop's processing to stay consistent to those sheets, you need to use the consistent variable.
ActiveSheet <> oSheet UNLESS you call oSheet.Activate in the loop before ActiveSheet.
But the better way to code it is:
Dim oSheet As Sheet
    If (oSheet.Name = "Jamb_typeG") Or (oSheet.Name = "Jamb_typeG:2")
    If (oSheet.Name = "Jamb_typeM") Or (oSheet.Name = "Jamb_typeM:2")
  Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
anthony.alam
worked perfectly, thank you so much!
