How to show only reference dimensions
atomic.lex
atomic.lex
Hi all,
i use ilogic for drawing dimentions. but i don't need all of them. Thats why a make a new sketch with reference dimentions. Those dimansions parameters ends with "_REF". I've tryed to use a code, which shows dimentions depends of parameter names, but it works not for reference dimentions. How can i mike it posable to use if for reference parameters too?
	For Each oView In oViews
		oRetDims = oDims.GetRetrievableDimensions(oView)
		If oRetDims.Count > 0 Then
			dimsEnum = oDims.Retrieve(oView)
			For  Each  oDim In  dimsEnum
				If oDim.Retrieved Then
					paramName = Dim.RetrievedFrom.Parameter.Name
					If Not paramName.EndsWith("_REF") Then
						oDim.Delete
				End  If
			Next
	Next
Thanks from Atomic Z
Have a nice day ☺
t_remal
could you please share the dataset too?
I can't reproduce any issue with the code you sent - parameters not ending with _REF are correctly deleted.
Lubomir
atomic.lex
Hi Lubomir,
this is only a part of code, which works not only for that task. For this task it should be so:
Dim oDoc As Document
 oDoc = ThisDoc.Document
Dim oViews As DrawingViews
 oViews = oDoc.ActiveSheet.DrawingViews
Dim oDims As GeneralDimensions
 oDims = oDoc.ActiveSheet.DrawingDimensions.GeneralDimensions
Dim oRetDims As ObjectCollection
Dim dimsEnum As GeneralDimensionsEnumerator
    paramName = oDim.RetrievedFrom.Parameter.Name
     oDim.Delete
  Next
Next
But it woks only for sketsh dimentions and not for references.
Have a nice day
Atomic Z
