ilogic - suppress component
marcin_bargiel
marcin_bargiel
I need a help with iLogic, i attached an example.
There are 3 rectangulars and 3 circles (cubes and cylinders in fact) - i created multibody part.
I have 2 rules in iam file. When rectangular or circle is small <10 i want to suppress components.
I want to do this by iLogic - moreover i DO NOT WANT to use trigger and run both 2 rules when open (for eg.)
All i want is to run just ONE proper rule.
When i change in ipt parameter a_rect, b_rect, c_rect <=10 then iLogic should suppress those components and run just rule_rectangular.
When i change in ipt parameter a_rect, b_rect, c_rect >10 then iLogic should unsuppress those components and run just rule_rectangular.
When i change in ipt parameter a_circ, b_circ, c_circ <=10 then iLogic should suppress those components and run just rule_circular.
When i change in ipt parameter a_circ, b_circ, c_circ >10 then iLogic should unsuppress those components and run just rule_circular.
Why? because i have hundreds of components and a lot of rules - and if i run all of them it take a long of time....
I wish I could use function Component.IsActive from ipt file - it'll be easier...
Vote for REPLACE VARIES !
REPLACE VARIES
rikard.nilsson
The only way I know how to have total control over rules when they should run or not is to use "Don't Run Automatically.." in Options and then use RunRule to start Rules.
But you if your new Rule only use one Parameter and none of the other rules. ILogic will only run that one.
/Rikard
b_sharanraj
hi @marcin_bargiel
Hope you are using 2018 Version so that I'm unable to look in to your attachment but still i tired my best.
Check the Option "Don't Run Automatically"  in iLogic rules option for both "Rule_Rectangular" & "Rule_Circular"
Create a new rule with the below code
If Parameter("ipt_Name", "a_rect") <=10 Or Parameter("ipt_Name", "b_rect") <=10  Or Parameter("ipt_Name", "c_rect") <=10 Then
Component.IsActive("ipt_Name") = False
iLogicVb.RunRule("rule_rectangular")
ElseIf If Parameter("ipt_Name", "a_rect") >10 Or Parameter("ipt_Name", "b_rect") >10  Or Parameter("ipt_Name", "c_rect") >10 Then
Component.IsActive("ipt_Name") = True
InventorVb.DocumentUpdate() iLogicVb.UpdateWhenDone = True
Regards
B.Sharan Raj
marcin_bargiel
Thank's but It will not work !  This new rule will not run, you would have to do it manually.
I did it differently by linking parameter from ipt file - now when this parameter changes - inventor automatically run rule (when that parametr appear...)
REPLACE VARIES
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @marcin_bargiel,
Is it working as per expectation?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
marcin_bargiel
Yes it's working as per expectation 🙂
Actually i stopped using Component.IsActive - now i use function Component.Visible - it's much better ! but there is a little bit inconvenience
when using Component.Visible in iLogic we have to use the second function Component.InventorComponent(FeatureName).BOMStructure = BOMStructureEnum.kReferenceBOMStructure to hide that component in BOM.
In my opinion there should be just one function to do so...
REPLACE VARIES
