Excel VBA to import iProperties in a celll?
fabianrebora
Message 1 of 16
fabianrebora
I need to make a list in excel of all files that I have Inventor.
List several of its iProperties (Part Number, stock number, Description, materials, ......)
I could only make a macro to access the properties that handles Windows (Name, Date Created, Folder, ……)
No programming in Visual Basic, only what you can find on the internet.
If someone could help me, I'll be very grateful
 ‘Force the explicit delcaration of variables
Option Explicit
Sub ListFiles()
‘Set a reference to Microsoft Scripting Runtime by using
‘Tools > References in the Visual Basic Editor (Alt+F11)
‘Declare the variables
Dim objFSO As Scripting.FileSystemObject
Dim objTopFolder As Scripting.Folder
Dim strTopFolderName As String
‘Insert the headers for Columns A through F
Range(“A1”).Value = “Name”
Range(“B1”).Value = “Size”
Range(“C1”).Value = “Type”
Range(“D1”).Value = “Date Created”
Range(“E1”).Value = “Date Last Accessed”
Range(“F1”).Value = “Date Last Modified”
‘Assign the top folder to a variable
strTopFolderName = “Q:\ArchivosCAD\Planera\ACUMULADOR (AC)”
‘Create an instance of the FileSystemObject
Set objFSO = CreateObject(“Scripting.FileSystemObject”)
‘Get the top folder
Set objTopFolder = objFSO.GetFolder(strTopFolderName)
‘Call the RecursiveFolder routine
Call RecursiveFolder(objTopFolder, True)
‘Change the width of the columns to achieve the best fit
Columns.AutoFit
End Sub
Sub RecursiveFolder(objFolder As Scripting.Folder, _
IncludeSubFolders As Boolean)
Dim objFile As Scripting.File
Dim objSubFolder As Scripting.Folder
Dim NextRow As Long
‘Find the next available row
NextRow = Cells(Rows.Count, “A”).End(xlUp).Row + 1
‘Loop through each file in the folder
For Each objFile In objFolder.Files
Cells(NextRow, “A”).Value = objFile.Name
Cells(NextRow, “B”).Value = objFile.Size
Cells(NextRow, “C”).Value = objFile.Type
Cells(NextRow, “D”).Value = objFile.DateCreated
Cells(NextRow, “E”).Value = objFile.DateLastAccessed
Cells(NextRow, “F”).Value = objFile.DateLastModified
Cells(NextRow, “G”).Value = objFile.ParentFolder
NextRow = NextRow + 1
Next objFile
‘Loop through files in the subfolders
If IncludeSubFolders Then
For Each objSubFolder In objFolder.SubFolders
Call RecursiveFolder(objSubFolder, True)
Next objSubFolder
End Sub
Replies (15)
Message 2 of 16
MechMachineMan
'Requires Apprentice Server Availability
'Add reference to Inventor Object Library Interop
Option Compare Text
Public oList As Collection
Sub UpdateFittingList()
    Dim FSO As New FileSystemObject
    ActiveWorkbook.ActiveSheet.Rows("3:" & Rows.Count).Clear
    Dim apprentice As Inventor.ApprenticeServerComponent
    Set apprentice = New Inventor.ApprenticeServerComponent
    Dim apprenticeDoc As Inventor.ApprenticeServerDocument
    Dim oFolderPath As String
    oFolderPath = "X:\CAD Files\"
    Dim oFolder As Folder
    Set oFolder = FSO.GetFolder(oFolderPath)
    Set oList = Nothing
    If oList Is Nothing Then
        Set oList = New Collection
    Call FolderList(oFolder)
    Dim i As Integer
    i = 2
    Dim vFolder
    Dim aFolder As Folder
    For Each vFolder In oList
    Set aFolder = FSO.GetFolder(vFolder)
    If aFolder.Files.Count = 0 Then
    Else
    For Each oFile In aFolder.Files
        If oFile Like "*.ipt" Or oFile Like "*.iam" And Not oFile Like "*Old*" Then
            Set apprenticeDoc = apprentice.Open(oFile)
            Dim InvDocDTP As Inventor.PropertySet
            Set InvDocDTP = apprenticeDoc.PropertySets.Item("Design Tracking Properties")
            Dim InvDocISI As Inventor.PropertySet
            Set InvDocISI = apprenticeDoc.PropertySets.Item("Inventor Summary Information")
            Dim InvDocIDSI As Inventor.PropertySet
            Set InvDocIDSI = apprenticeDoc.PropertySets.Item("Inventor Document Summary Information")
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 1) = FSO.GetFileName(oFile)
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 2) = InvDocDTP.Item("Stock Number").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 3) = InvDocIDSI.Item("Category").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 4) = InvDocISI.Item("Keywords").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 5) = InvDocDTP.Item("Description").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 6) = oFile
            Call apprenticeDoc.PropertySets.FlushToFile
            Set apprenticeDoc = Nothing
            i = i + 1
    Next
    Next
    Call apprentice.Close
    Set apprentice = Nothing
End Sub
Public Sub FolderList(oFolder As Folder)
oList.Add (oFolder)
If oFolder.SubFolders.Count = 0 Then
    Exit Sub
Dim xFolder As Folder
For Each xFolder In oFolder.SubFolders
    If xFolder.Path Like "*Old*" Or xFolder.Path Like "*Legacy*" Then
        'MsgBox (xFolder.Path)
    Else
            Call FolderList(xFolder)
Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 16
fabianrebora
Thank you very much for your answer
Enter the FolderPath = "Q: \ ArchivosCAD \ Planera \ accumulator (AC)"
And a compilation error occurs (is not defined type user-defined) in this line
Public Sub FolderList (oFolder As Folder)
It has also given me in this line herror
Sub UpdateFittingList ()
     ActiveWorkbook.ActiveSheet.Rows ( "3" & Rows.Count) .Clear
     Dim As apprentice Inventor.ApprenticeServerComponent
I have to enable some Excel add-in to run this macro?
I'm trying to achieve something like a progam called UnReserveAndExport, that works for Inventor 2016.
Sorry for my English, it is enough to read and use a translator to write
Message 4 of 16
MechMachineMan
I think you also need to add a reference to Microsoft Scripting Runtime to
be able to use FileSystemObjects
Justin K
Message 5 of 16
fabianrebora
I found the problem.
Open the Microsoft Visual Basic (for Application) window through clicking the Developer ribbon tab -> Visual Basic button in the Code ribbon panel.
Open the References dialog by clicking the Tools menu -> References item. Find the Autodesk Inventor Object Library from the checkable list box and tick it
Message 6 of 16
fabianrebora
Justin, thank you very much for your previous help.
It has been very useful to me.
But, I have to ask again.
Is it possible to place a miniature view in a cell?
As in the new 2018 version.
Thank you very much for your help.
 Sorry for my english, I used google translator to correct my grammatical errors.
Option Compare Text
Sub Listarplanosinventor()
'Declare the variables  AGREGADO POR MI
'Insert the headers for Columns A through F AGREGADO POR MI
    Range("A1").Value = "PLANO"
    Range("B1").Value = "REVISION"
    Range("C1").Value = "CODIGO BAS"
    Range("D1").Value = "TIPO"
    Range("E1").Value = "LINEA"
    Range("F1").Value = "EQUIPO"
    Range("G1").Value = "SUBCONJUNTO"
    Range("H1").Value = "DESCRIPCION"
    Range("I1").Value = "MATERIAL"
    Range("J1").Value = "PDF"
    Range("K1").Value = "CARPETA"
    Range("L1").Value = "3D"
    Range("M1").Value = "2D"
    Range("N1").Value = "UBICACION"
    Range("O1").Value = "ARCHIVO"
'PROGRAMACION ORIGINAL
    'ActiveWorkbook.ActiveSheet.Rows("3:" & Rows.Count).Clear
    oFolderPath = "Q:\ArchivosCAD\Planera"
    Set oList = Nothing
    Dim i As Integer
    i = 1
    Dim vFolder
    Else
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 1) = InvDocDTP.Item("Part Number").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 2) = InvDocISI.Item("Revision Number").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 3) = InvDocDTP.Item("Stock Number").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 4) = InvDocISI.Item("Subject").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 5) = InvDocISI.Item("Title").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 6) = InvDocIDSI.Item("Category").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 7) = InvDocISI.Item("Keywords").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 8) = InvDocISI.Item("Comments").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 9) = InvDocDTP.Item("material").Value
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 14) = oFile
            ActiveWorkbook.ActiveSheet.Cells(i + 1, 15) = FSO.GetFileName(oFile)
            i = i + 1
    Next
    Next
End Sub
oList.Add (oFolder)
    Exit Sub
    Else
Next
End Sub
Message 7 of 16
MechMachineMan
If you really need pictures, yes there is ways to do it. There should be sources on the forums here you can find.
Or, you can export BOM with thumbnails exposed and sort that data into whatever way you like.
Justin K
Message 8 of 16
fabianrebora
Is it possible to add a VBA code to generate it and add it to the excel list I already have?
To be generated in the same way as when exporting to excel with inventor?
thanks for your help
Message 9 of 16
MechMachineMan
Sure.
Something like this should get you on the right path.
Private Sub MakeThumbnailColumn(oStartRow As Integer, oTColumn As Integer, oFileNameColumn As Integer)
    oLastRow = ws.Cells(ws.Rows.Count, oFileNameColumn).End(XlDirection.xlUp).Row
    For j = oStartRow To oLastRow
        oFName = ws.Cells(j, oFileNameColumn).Value
        If Dir(oFName, vbDirectory) = vbNullString Then GoTo SkipRow
        On Error GoTo SkipRow
            Set apprenticeDoc = apprentice.Open(oFName)
        Dim Thumbnail As IPictureDisp
        Set Thumbnail = apprenticeDoc.PropertySets.Item("Inventor Summary Information").Item("Thumbnail").Value
        Call CreateThumbnail(Thumbnail, oTColumn, j)
        Call apprenticeDoc.Close
SkipRow:
    Next
    apprentice.Close
End Sub
Private Sub CreateThumbnail(Thumbnail As IPictureDisp, oColumn As Integer, ByVal CellRowNum As Integer)
    'Changed to put N/A in same column as comments. if there is an error, check this first.
    On Error GoTo Handler
    Call stdole.SavePicture(Thumbnail, "C:\Temp\Thumb.jpg")
Handler:
    If Err.Number = 380 Then
        ws.Cells(CellRowNum, oColumn).Value = "N/A"
        Exit Sub
    With ws.Cells(CellRowNum, oColumn)
            .AddComment
            .Comment.Visible = False
            .Comment.Shape.Fill.UserPicture ("C:\Temp\Thumb.jpg")
            .Comment.Shape.Height = 75
            .Comment.Shape.Width = 75
    End With
End Sub
Justin K
Message 10 of 16
fabianrebora
Sorry for my ignorance on the subject, but in which part of the old code do I have to insert this new code?
Message 11 of 16
MechMachineMan
Above is written as a VBA function that uses 'ws' as a global variable.
To implement, you need to call the function. (Make a module in excel (Alt + F11) and drop all of that code in)
Then above that, type this in as a calling sub.
Save the module, go back to excel and run the macro. Or in the Alt-F11 Window, with your mouse in the name SomeStringNameThatWillExecuteThisCode() Press F5.
Private ws As Worksheet
Public Sub SomeStringNameThatWillExecuteThisCode()
     Set ws = Application.ActiveSheet
'Sub MakeThumbnailColumn(oStartRow As Integer, oTColumn As Integer, oFileNameColumn As Integer) Call MakeThumbnailColumn(2, 3, 4)
End Sub
This assumes your spreadsheet looks this:
row1:    Column A | Coumn B   | Thumnail Column | FileName Column
row2:    something| something | *thumbnail*          | "C:\File.ipt"
ie; a header row, and then column 4 containing the file name of the file you want a thumnail for.
Justin K
Message 12 of 16
fabianrebora
I will try to see how to join those two codes.
I have not at the moment
Message 13 of 16
fabianrebora
Unfortunately I can not figure out how to generate the code.
I dare to attach the form that I use to generate the master list.
With the code that you gave me before.
If you can help me to modify the code I will be very grateful.
Sorry to bother you,
If you can not, thank you very much too.
The code above was of great help to me
Message 14 of 16
MechMachineMan
Well, I told you exactly how to get the thumbnails, yet I see no effort of even attempting it in your code.
Again, simply copy both of the chunks of code I pasted and put them in 1 module. Tweak the integers used in the calling function "MakeThumbnails..." to match where you want your data read/exported to.
Also, you need to modify your spreadsheet format to include a column that has the FILE NAME of the model for this solution to work.
Justin K
Message 15 of 16
fabianrebora
Okay, thanks for your help
Message 16 of 16
fabianrebora
Thanks, I finally made it work
Change in the schedule where WS says by Application.ActiveSheet.
Change also that it is always visible.
I only need to see to make it move and resize with the cell.
And if I run it again without deleting the comments, it does not work.
I guess I have to add before I delete the entire column.
But, you are inserting as a comment.
Not as embedded image
Change part of the programming, but only that it generates the images but one above the other
And without defining properties. Width and height.
At the moment this is the result, inserting comment
