Co-planar faces
Co-planar faces
DWhiteley
Advisor Advisor
Co-planar faces
DWhiteley
I've selected a face on a part & I wish to select any other faces that are co-planar to it (in the same part).
Can anyone suggest a way to do this in the API?
Thanks in advance,
Dave Whiteley
Envisage Uk Ltd
Mario-Villada
Hi Dave, I think you can achieve this by using the metgod IsCoplanarTo for planes. So basically you can create a plane from the selected planar face and then cycle through all faces in the part, create a plane from each planar face and check if it is coplanar.
try this VBA Code:
Public Sub SelectCoplanarFaces()
    Dim oDoc As Document
    Set oDoc = ThisApplication.ActiveDocument
    If Not TypeOf oDoc.SelectSet(1) Is Face Then
        MsgBox "A face must be selected."
        Exit Sub
    Dim oFace As Face
    Set oFace = oDoc.SelectSet(1)
    If Not oFace.SurfaceType = kPlaneSurface Then
        MsgBox "A Flat face must be selected."
        Exit Sub
    Dim params(1) As Double
    params(0) = 0.5
    params(1) = 0.5
    ' Get point on surface at param .5,.5
    Dim points(2) As Double
    Call oFace.Evaluator.GetPointAtParam(params, points)
    ' Create point object
    Dim oPoint As Point
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint(points(0), points(1), points(2))
    ' Get normal at this point
    Dim normals(2) As Double
    Call oFace.Evaluator.GetNormal(params, normals)
    ' Create normal vector object
    Dim oNormal As Vector
    Set oNormal = ThisApplication.TransientGeometry.CreateVector(normals(0), normals(1), normals(2))
    Dim RefPlane As Plane
    Set RefPlane = ThisApplication.TransientGeometry.CreatePlane(oPoint, oNormal)
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim bodies As SurfaceBodies
    Set bodies = oPartDoc.ComponentDefinition.SurfaceBodies
    Dim BodyFace As Face
    Dim PlaneB As Plane
    For Each Body In bodies
        For Each BodyFace In Body.faces
         If BodyFace.SurfaceType = kPlaneSurface Then
            Call BodyFace.Evaluator.GetPointAtParam(params, points)
            Set PlaneB = ThisApplication.TransientGeometry.CreatePlane(oPoint, oNormal)
            'Check if they are co-planar
            If PlaneB.IsCoplanarTo(RefPlane) Then
                Call oPartDoc.SelectSet.Select(BodyFace)
        Next
    Next
End Sub
Hope this Helps.
Mario.
