excel and inventor
excel and inventor
GosponZ
excel and inventor
GosponZ
I'm trying to export few iProperties into Excel but on this line shows me error
SyntaxEditor Code Snippet
Dim Names={"Display name", "Title", "Part Number", "Date", "Revision"}
Array initializers are valid only for arrays, but the type of 'Names' is 'Object'
Can you guys guide me in right direction, please.
'Try the following rule to debug the export of your iProperties to the Excel workbook.
'It assumes that the active document is an assembly
'open the existing excel file
GoExcel.Open("c:\TEMP\EXPORT.xlsx", "Sheet1")
'Print column titles in the row 2
GoExcel.CellValues("A2", "E2") = Names
Dim oAsmDoc As AssemblyDocument = TryCast(ThisApplication.ActiveDocument,AssemblyDocument)
If oAsmDoc Is Nothing Then
	MessageBox.Show("Activate assembly document first", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Information)
	Exit Sub
End If
Dim Data(4) As String	'string array for properties
Dim row As Integer = 3	'start data row
Dim oPropSet As PropertySet
Dim oProp As Inventor.Property
For Each oDoc As Inventor.Document In oAsmDoc.AllReferencedDocuments
	'full filename
	Data(0) = oDoc.FullFileName
    'Title
    oPropSet = oDoc.PropertySets.Item("Inventor Summary Information")
    oProp = oPropSet.Item("Title")
	Data(1) = oProp.Value
    'Part Number
    oPropSet = oDoc.PropertySets.Item("Design Tracking Properties")
    oProp = oPropSet.Item("Part Number")
	Data(2) = oProp.Value
    'Date
    oProp = oPropSet.Item("Creation Time")
	Data(3) = oProp.Value
    'Revision
    oProp = oPropSet.Item("Revision Number")
	Data(4) = oProp.Value
	GoExcel.CellValues("A" & CStr(row), "E" & CStr(row)) = Data
	row += 1
Next
GoExcel.Save
GoExcel.Close
MessageBox.Show("Done", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Information)
Here is whole code i found i beleive in this forum. Thanks for help
Dim Names(4) as string
Names = {"Display name", "Title", "Part Number", "Date", "Revision"}
GosponZ
GosponZ
When i try on Inventor 2015 it is working very well and i acepted as solution, but with  Iv2012 do have problem
LIne 6: Expression expected
 what is difference?
Thank you for any advice
GosponZ
It is just wierd, any advice?
