Hi Darren,
Did you want something like a derived part? If so, try this VBA:
Sub DerivedAssembly()
' Open the assembly to be saved as a derived part
' Get the path for the current Assembly
Dim strAsmPath As String
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
strAsmPath = oAsmDoc.FullFileName
' Create a new part to derive the assembly into.
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject))
' Create a derived definition for the assembly.
Dim oDerivedAsmDef As DerivedAssemblyDefinition
Set oDerivedAsmDef = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.CreateDefinition(strAsmPath)
' Create the derived part from the assembly.
Call oPartDoc.ComponentDefinition.ReferenceComponents.DerivedAssemblyComponents.Add(oDerivedAsmDef)
' Save the new part
ThisApplication.SilentOperation = True
Call oPartDoc.SaveAs("c:/Temp/DerivedPart.ipt", False)
ThisApplication.SilentOperation = False
End Sub
FYI,
Clare
